Question about Tomtom XL 325 SE GPS Receiver
I have a problem: My gps (tom tom XL 3255) It will not give me direction or let me put in direction. It keep cutting off and the battery is full. Can i download something from my computer to the device to fix it
  • 39 Answers
SOURCE: I need to reset the time on my Tom Tom XL330S
Tap "Set clock" button to select the type of clock that is shown and set the time.
Posted on Apr 20, 2009
  • 16 Answers
SOURCE: i am not getting satalite signal on my tom tom xl
The most common problem to this is because the TomTom doesn't know it's current location.  It may be that you last used your device a long distance from where you currently are now.  I don't know how long you waited for the gps signal to acquire but it can take up to 10 minutes (even on military aircraft if they don't know current location).
Power it up and press on the signal strength icon.  That will bring up your satellite tracking status.  If it don't look like it's doing anything, then your gps has probably malfunctioned.  If it looks like it's acquiring satellites, then give it a good amount of time (10-15 minutes) to see if it can find your location.  I recommend doing it outside of your vehicle with no satellite obstructions to make the process go faster.
Good Luck
Posted on Jun 11, 2009
SOURCE: My HTC TyTN II GPS
I Got it!
I finally got my HTC TyTN II yesterday from Dubai.
First thing I wanted to test was the GPS. It did not work with: TomTom6, Google Maps, Yahoo Go.)
I was surfing around to find something that would help me out and have noticed that many people have the same problem.
Many people (Like me) did not know howe to setup the GPS.
Many people are saying: "You have to put it your GPS settings in Com 4 and the Baud rate on 4800 and it should work.
Well mine didn't work with those settings. (Along with other people.)
I had played with the External GPS option (Don't do this cause setting something wrongm ay cost you a HARD-Reset.)
I Was lucky that mine worked again after a SOFT-Reset. So watch out!
The standard GPS settings! (If you have changed it, Soft-reset your phone and set it up as these pictures show.)
Why am I doing this?
People buy this phone to make use of it. When something does not work why buy the phone then :S
Hope that this may help a lot of people on here and other forums, communitys & websites.
Here is my story of how I did get my GPS to work:
1. Download the GPS addresses by using QuickGPS (Start -> Programs -> QuickGPS).
(This will download info of what your GPS Reciver needs to connect to the satalites.)
2. Download a free (Well half free, You can also buy this application it will give you some extra options, but we don't need those extra options.) tool named: GPS Test. (http://www.smartphone.net/software_detail.asp?id=3170 or at http://www.pocketpc-software-downloads.com/software/t-free-pocketpc-gps-test-download-uykfcoyy.html)
(This program will scan all your mobiles com ports and Baud rates, To see what your real GPS settings are.
In my case they were: COM PORT: 4 - Baud Rate: 9600 (Notice it ain't 4800. Usaly it shows your settings with a pop-up.
When It doesn't Go to "Menu -> GPS Settings", There it will show you you're GPS settings.)
3. Install TomTom 64. Download your free map.
5. Go to the GPS settings.
(Set-up: Other NMEA GPS-Reciver -> GPS-Baud Rate -> Com. (Select the Baud rate + Com port from what the GPS Test did show you.)
6. Now wait.
Posted on Jul 27, 2009
SOURCE: Tom tom gps speakers not working.
The exact speaker you require can be obtained from DCC Supplies. (www.dccsupplies.com) model # 995200014 price £4.12 plus p&p.
Posted on Mar 30, 2010
  • 20 Answers
SOURCE: I have a TOM TOM one XL GPS and it will not power
If you where having difficulty with the on/off button, it sounds like the microswitch under the plastic. Unless you can do micro soldering you can not fix this yourself. You should get a quote from tomtom.
Posted on May 30, 2010
Testimonial: "Thanks for the advice"
Tom tom keeps turning off ?????
The internal rechargeable battery has failed; they don't last forever.
Just search "TomTom One XL battery" and you'll find the the parts and step by step guidance on what to do.
May 28, 2010 | Tomtom One XL GPS Receiver
Voice
http://www.tomtom.com/services/service.php?id=16&tab=87 link to keep you up to date, according to tom tom.
http://download.tomtom.com/open/manuals/go/ttgo_manual_uk.pdf Manual that might tell you where to find what you are looking for.
Hope this helps.
Apr 26, 2010 | Tomtom ONE XL GPS
If it needs to be charged for 2 hours will it run down your car battery???
mostly they only suggest charging it for extended periods of time the first time you charge it because it comes dead after that the lighter port in your vehicle should be giving off way more than needed to keep the lil guy running i have used a tom tom for years now and have never had a problem with excessive drain on my electrical system
Mar 30, 2010 | Tomtom XL 330S GPS Receiver
My tom tom wont turn on where is the reset bitton
look for a small hole on the outside case near the sd card reader. might need a paperclip or pin to poke the microswitch inside the hole. simply clicking the switch doesn't work, try holding it for 5 seconds then try to power up. Common problem with GPS devices, (my mio included) is after being plugged in for a long time, the battery life becomes nil and it relies upon the charger. Check tom to xl for further problem solving. google search TOM TOM XL won't power up.
Mar 14, 2010 | Tomtom XL 340S Car GPS Receiver
Waiting for a valid gps signal
A couple solutions:
1) Make sure the TomTom can "see" the sky well... the GPS satellite waves are rather weak and easily blocked by trees, and anything not a window.
2) Hook up your TomTom to the computer (see details at www.tomtom.com or in the manual)
2b) Do a "sync" and download all updates. One of the updates is a small file that tells the TomTom where the satellites are located this week, and helps it sync up much faster. The longer time between uses, the longer it takes TomTom to find the satellites, and that can takes up to 2-5 minutes sometimes.
That can be frustrating with a car full of people waiting to get going and the driver doesn't want to drive without making sure the TomTom works and is giving valid directions.
Aug 16, 2009 | Tomtom One XL GPS Receiver
Tom tom gps in sleep mode
try replacing the internal battery
Jul 05, 2009 | Tomtom ONE GPS Receiver
Tomtom XL 325 SE GPS Receiver Logo
66 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
