Question about Lexmark X5470 All-In-One InkJet Printer
Lexmark X4850 paper jam
Lexmark X4850 has a paper jam error on the printer but there is no paper. power down does not work - wht buttons do I hold down to access a settings menu on the printer??
  • 3 more comments
  • Anonymous Aug 24, 2008
    Paper Jam message appears when printer is started. Cannot get the printer to go past this message
  • rogersle Sep 07, 2008
    I have a paper jam msg but there is no paper anywhere in the printer. How do I fix my problem? rogersle@aol.com I followed the on-screen directions several times to no avail.
  • Anonymous Feb 17, 2009
    No paper in the printer but can't get passed teh message
  • Anonymous Apr 20, 2009
    Lexmark X4850 has a paper jam error on the printer but there is no paper. Turning it off...then restarting it does not clear the error message, neither does pressing the check mark (ok) button.
  • Anonymous Mar 12, 2014
    lexmark t642 shows error 202.03 paper jam but no jam found what must i do
    Genius:
  • 2,035 Answers
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on May 13, 2008
  • 29 Answers
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
847
Posted on Mar 02, 2009
Getting message that I have a paper jam but there isn't on to be fpund
Try checking the printer for foreign objects that might be interfering with the paper path. Tilt the printer sideways and try shaking it a bit. After that, try printing. If the issue persists, clean the rollers of the printer.
Dec 13, 2012 | Lexmark X4850 WIRELESS All-In-One InkJet...
Printer says paper jam but no paper is in it
Hi
Clear any print queues.
Turn the printer off and on.
Try disconnecting/unplugging the printer from power.
Connect it after a while.
Try printing.
Mar 03, 2012 | Lexmark X4850 WIRELESS All-In-One InkJet...
On printer error cod 6A00 displayed, on computer screen icon says service error 5C10. Have cleaned ink wells and wiped off excess ink. After cleaning far right side a long skinny black piece came out,...
Hi
Error 5C10 means a paper jam or the printer has encountered an internal error. And error 6A00 is caused due a paper jam in the sheet feed unit or near the print head. You can also reset the printer to resolve this issue. On the printer press and hold the ON/OFF button or unplug the power cord. Wait for 10 seconds, press power button ON/OFF button again. If this doesn't resolve the error code then unplug the printer for 10 minutes. Also, inspect the back panel of the printer for any paper jams. To clear the paper jams---
Turn off the printer and disconnect the power cord and USB cable. Remove the jammed paper slowly using the following procedure. Open the rear cover to check if the paper is jammed. Pull out the cassette and check if the paper is jammed inside the cassette area. Stand the printer with the rear side down, holding the document cover. Press the tabs together and pull the green cover toward you. Check if the paper is jammed. (If you were not doing Duplex printing, you do not have to follow this procedure.) Close the green cover and place the printer back to a normal position. Reconnect the power cord and power on the printer. Confirm the Alarm light is off. Load paper back into the ASF or cassette. Press to clear the message and continue printing. If you are printing from application software, follow the instructions displayed on your computer. Hope this helps... Please post back if you need more information.
Daniel
Jun 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
My Lexmark shows always paper jam even without paper in the printer.
Just needs reset hold down power button for three seconds shold work or unplug and plug back in.
Oct 31, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
I have a MacBook, and a Lexmark E232 laser printer. It has worked fine for several years but all of a sudden when I try to print the light for the light for a paper jam comes on. I have cleared it, and...
The problem is that the printer thinks that there is a paper jam inside the printer. What could be happening is that there was a paper jam the paper was pulled out but the actual sensor that detected the paper probably got damaged, either broken or malfunctioning. In this case try the following, turn off the printer and open the front cover. Then press and hold down the two front buttons while having the cover open and turn the printer on. Then wait untill the bottom light stays on solid then release the buttons that should reset the printer. If after that the paper jam error does not go away then you are probably looking at a damaged sensor. To fix that you will have to take it in to have it service.
Hope it helps.
Mar 19, 2010 | Lexmark E232 Laser Printer
Lexmark x7550 printer jam. I cleared the jam and hit the check mark button as directed, but it keeps looping through the paper jam sequence. It does not seem to register that the jam has cleared. If I...
There will be some form of error clear code that would need to be entered. It would be something like "holding down the print key and powering on the printer at the same time" The manual may tell you.
There are different combos for different manufacturers.
Nov 17, 2009 | Lexmark X7550 InkJet Printer
Lexmark 6500 states I have a paper jam, but I don't.
Hooray for McGuyver techniques, but I just shoved a piece of paper in there so it actually had a jam, pulled it out, and it cleared fine!
Sep 22, 2009 | Lexmark X2550 All-In-One Printer
Unisys model uds25 has a error message "invalid engire"
on power up let me guess the most frequent errors on power up are 922 fuser error means ac circuit is open replace the fuser. 201 jam error no paper present replace the main motor drive. 954 nvram error hold right arrow go and reutrn buttons down power on the machine if it doesnt reset repplace the engine board this is just a band aid thie error is known to return. there are also several scanner errors that can come up a biy more info would be good
Feb 19, 2009 | Lexmark Optra T614 Laser Printer
Dell 924 printer paper jam; don't have a # sign or number to reset
Hi
If there is a error msg on the operator panel of the printer, try the following steps
1.press and Hold the start button and the cancel buttom on the printer and holding them down unplug the Power adapter from the printer , wait for abt 30 secs and then put back the power adapter and then release both the buttons.
2. manually move the rollers present inside the paper tray, lift the printer and shake it firmly , turn the printer upside down and gently tab on it , put back the power adapter and then turn on the printer , if it still gives the same error msg , then purchase the new printer
Apr 21, 2008 | Dell 924 All-in-One InkJet Printer
Paper Jam
The problem is that after the cover sensor clip is replaced, the logic that tells the printer to feed the paper just to the beginning of the input roller is corrupted. The feeder roller (grey one at the paper feed) rolls to feed the paper and once the paper get to the input roller, another switch detect the paper, that tells the logic to change the direction of the input roller to feed the paper to the cartrige.
There's should be a way to reset the logic part of the printer to get it working right. Maybe pushing a combination of the front panel buttons.
Try playing with the power/green or power/"X" while unplug and plug the power cord.
Good Luck!!! email me with more sugestions/ideas... jmjc_65 at hotmail...
Jan 15, 2008 | Lexmark X3470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
1,616 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
