I cant figure out how to connect my jornada to my pc.. can you help?
  • 503 Answers
Are you connecting from dock to USB on computer, or serial to USB via a USB-serial adapter? UBS-serial adapters are notorious for not recognizing attached serial hardware. What kind of errors are the Jornada and the computer throwing? Can you give any specific error numbers?
If you are connecting using the serial cable to a serial port on your computer you need to make sure that the Jornada is trying to connect to the correct COM port (and that the computer is allowing connections through the correct COM port). Do this by:
1. Open Device Manager (R-Click on My Computer - Properties - Hardware - Device Manager)
2. Expand the "Ports (COM)" plus sign
3. Beside each COM port's name it will say (COM#) - the # tells you which port the COM is
4. Go into ActiveSync and open Connection Settings (in the File menu in ActiveSync 4.5 - the latest)
5. Make sure all the check boxes are checked and that the correct number COM port is selected in the drop down menu under "Allow connections to one of the following:"
6. Connect your Jornada via the serial cable, make sure the Jornada is on and connected to power cable (I have had more success with the power on - may or may not affect your problem)
7. Click the "Connect..." button in ActiveSync. The Jornada should be detected.
If your computer has an infrared port you could try that, I have had a lot of success with infrared connections with my Jornada. Also, try installing ActiveSync on another computer that has a serial port and try connecting the Jornada to that computer. It may be a problem with your computer.
An older version of ActiveSync should not make a difference. The facilities are the same, just slightly rearranged.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Sep 01, 2010
Where can I find a driver for HP jornada 520 to Windows 7
You don't need drivers to link your HP Jornada 520 Pocket to your Desktop/Laptop Win 7 PC.
Download & refer to the "HP jornada 520 user manual" @ http://mikechannon.net/holdingfile/HP_JORNADA_520_User_manual_EN.pdf
All instructions are included at "Connecting to your Desktop PC" in the pdf file.
Hope it helps.
Mar 29, 2011 | Computers & Internet
Hp jornada 720 handheld pc
Try a older version of active sync. 3.0 or 3.1
heres 3.1
http://www.tucows.com/preview/32548
Feb 17, 2008 | HP Jornada 720 Pocket PC
AC Adapter Buzz Noise
The jornada 548 power adapter should not be buzzing - it should be very quiet.
Sep 12, 2005 | HP Jornada 548 Pocket PC
Can I update jornada 525 to poquet pc 2002 ?
Unfortunately, the Jornada 525 cannot be upgraded to Pocket PC 2002. The Pocket PC 2002 operating system requires a handheld with a StrongARM processor. The Jornada 525 has a Hitachi SH-3 processor.
Sep 12, 2005 | HP Jornada 525 Pocket PC
Can't synch, only connects as guest
I have had this happen to me at work. You need to backup your Jornada on the computer that works to sync (VERY IMPORTANT) and then hard reset the Jornada (which wipes it clean). Make sure that you put the name back into the Jornada identification (it will be wiped out by the hard reset). Then try to synch on the computer that can't synch except as Guest now. It should sync fine. Then you will need to sync on the computer that works to sync to restore the backup file. Then you will be back to normal. It is a pain. I don't know why it happens but I know this solution worked for me. Let us know if it works for you.
Sep 12, 2005 | HP Jornada 568 Pocket PC
Jornada 565 no longer being seen by ActiveSync?
Occasionally under XP Pro, my 564 won't be recognized when I put it on the cradle to sync. I just take it off the cradle and try again. My understanding is the XP loads an HP driver when the Jornada is detected as connected by USB, if that driver doesn't load succesfully, then XP won't recognize the Jornada.
Sep 12, 2005 | HP Jornada 565 Pocket PC
Jornada 680 won't sync over network
Hi. Put your desktop ip-address into your network card wins-address field (on your Jornada) Works for me :)
Sep 12, 2005 | HP Jornada 680 Pocket PC
Change language in hp jornada 540 pocket pc
Sorry, the OS on the Jornada 540 is in ROM and cannot be changed.
Sep 12, 2005 | HP Jornada 540 Pocket PC
USB connectivity for Jornada 520
This may be a simple case of removing all the entire active sync directory. If you used to connect via serial+com it wont be detected on usb. Remove active sync from your pc via the add remove program feture, then reboot and re install. Then run the make a connection again from active sync. Hope this helps
Sep 12, 2005 | HP Jornada 520
Can't find drivers...
should work with active sync, let me know if you have any problems with it.
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-synch.mspx
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
