Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
I ger AMP error ("Pull out AC cable, check your connection) all the time in all inputs of a new 46" Sharp AQUOS LC-46D85U 1080p 120Hz
I had the same problem with a Sharp Aquos 40". Sound just for a second and the message all the time in the middle of the screen, no more sound.
I opened the TV and found a speaker cable (a black one) with the PVC isolation broken and the wire in contact with the chassis. I just isolated it, the sound came back and no more error message.
Posted on Nov 19, 2010
  • popeyefixit Mar 13, 2011
    I had the exact same problem. i followed Jorgenrique's advice and sure enough found a pinched wire. A little electrical tape and I was all set. Easy solution, beats calling a Sharp warranty tech.
    Cheers!
Somehow getting access to the actual internet on my aquos sharp TVLC
The TV will connect to your wireless router but not other devices in your network. You can connect to a HDMI port with a cable to your PC and select that port on the TV.
Jul 27, 2016 | Sharp " AQUOS - 70"" Class - LED - 1080p -...
Reset secret number on sharp aquos
ROFLOL and we are supposed to know it .or guess ,or read your mind from afar .
Nov 21, 2015 | Sharp Aquos Quattron LC-46LE810UN 46-inch...
Sharp aquos lc-46le810un won't power on, psu diode zener and fuse blows..cause?
Unhook the PSU from everything that you can and turn it on, see if it blows anything out. If it does not then you are looking at a non PSU problem. If it does then it is psu. You need to get the schematics for this set if you can.
Aug 09, 2014 | Sharp Aquos Quattron LC-46LE810UN 46-inch...
Sharp troubleshooting
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Aug 03, 2014 | Sharp LC-C4677UN Aquos 46 120Hz Full 1080p...
Getting blank white screen and error code cs31-700
This is related with tuner fault. Check this link. It has blinking codes to many brand TVs, including Sharp models. Pull up older posts. http://electronicshelponline.blogspot.com/
Jun 03, 2013 | Sharp LC-52LE820UN AQUOS 52 Inch 1080p...
Sharp Blue Ray and Sharp Aquos TV were working just fine, now blue ray not recognized by tv; screen stays dark but the blue ray appears to be operating. Have tested the blue ray independently and worked...
A refurbished set? If blue ray is not built into set the issue is with the set--maybe the reason set was refurbished.....If have not tried it unplug set for a while and reconnect with set turned off.
May 01, 2012 | Sharp Aquos Quattron LC-46LE810UN 46-inch...
Sharp LC 46D85U TV with NO SOUND (but perfect picture)
Sound like the TV has a defective audio board. Opening up the TV would most likely void the warranty.
It's best to take the TV back and exchange it for a new one. Personally, I wouldn't want to be stuck with a defective TV ( that just came out of the box ) that they are going to repair for you.
Jul 04, 2009 | Sharp AQUOS LC-42D85U 42 in. LCD TV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
923 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
