Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Water is leaking in my fridge, a puddle of water accumulates under veggie bins. Can I fix this problem? If so how? or do I need to hire a professional?
    Sergeant:
  • 239 Answers
If you want to attempt fixing, remove back freezer panel, use hair dryer to melt ice in drain pan under coils, pour hot water in pan till drain clears.
Posted on Sep 01, 2010
Mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
Mar 07, 2016 | Daewoo Refrigerators
I have a whirlpool refrigerator. I have water
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 10, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Hi, I have a 20.9 cf (#ET1CHK/ET1CHM). Water
I HAD THE SAME ISSUE EVERY FEW MONTHS. REMOVE THE BACK COVER IN THE FREEZER, YOU WILL SEE A SILVER TRY WITH MOST LIKELY ICE IN IT. THAW THAT ICE AND THERE IS A DRAIN HOLE IN IT. USING A HAIR DRIER GET THE TUBE TO THAW ALSO. ONCE WATER IS FLOWING TAKE A PIECE OF 12 GAUGE BARE COPPER WIRE AND SLIP IT ABOUT 18" INTO THE HOLE. WRAP THE OTHER SIDE OF THE WIRE AROUND THE WIRE COIL YOU SEE WHICH IS THE DEFROSTER. WHEN IT WARMS IT WILL HEAT THE WIRE ALSO AND KEEP THE DRAIN CLEAR
Dec 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is pooling under the veggie bins- watere even came down via freezer door gasket to the floor. I have been noticing water in the right meat bin and in veggie bin, and under them for 2 weeks. most of...
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 12, 2009 | Liebherr European Right Hinge Fully...
Water leaking along back interior to bottom under & over veggie bins
Sounds like the drain to the drip pan is clogged -- maybe with ice.
Defrost water runs down to a drain in the bottom of the fridge and into a pan underneath where it evaporates.
Sounds like the defrost water is not reaching its final destination.
Here's the way the same problem was solved earlier today:
For those who have this problem with this model: The drip pan is in an open space on the back side of the refrigerator. There is a rubber spout that empties into it. But to clear clogs...you must take out the shelves from the freezer, unscrew and remove the back panel on the inside of the freezer. There you will see the water exit. Boiling water cleared it out.
May 29, 2009 | GE Refrigerators
Small amt. of water dripping from behind veggie bin
Hi, It sounds like the tank for the fresh water dispenser. Is it coming from the tank on the back wall of the fresh food section?
I can not find the part # but, if this is the source of the leak, I can give other ideas.
Please let me know if I can assist you further.
Vic
May 24, 2009 | Samsung RS2630SH Side by Side Refrigerator
Accumulation of water in bottom of fridge
You probably need a new door deal for the freezer. When you cet too much condensation in the freezer, it drains down the back of the refrigerator section during the defrost cycle. Check under the produce bins for a drain. If you don't have one, you're not alone. I used to have have to wipe mine out every other day until I finally replaced the seal.
Feb 02, 2009 | Frigidaire FRT21G4B Top Freezer...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
161 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
