Question about Water Heaters
The powerwill light but when u turn it on the burner go out
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
Replace the thermocouple first, if that does not fix it you will need to replace the gas control valve. Contact the manufacturer for free parts and detailed safety instructions.
Posted on Sep 01, 2010
I have a bosch aquasar 125b tankless water heater and the burners do not light when hot water is turned on this also causes the pilot light to go out
possible faulty pressure switch connected to the water line and that is failing to turn on the main gas tap solenoid
best have it checked by an accredited gas fitter or service center for the make
Aug 20, 2016 | Bosch AquaStar Indoor Natural Gas Tankless...
I light pI lot and it stays lit burners light and reach temp but then burners wont relight to keep temp unless I tap gas valve..is it my gas valve
A lot of pilot lights have a thermal coupler... the pilot light must be lit for several min to open the coupler so the pilot light will not go out.... the newer systems use an electronic ignition and no pilot light and need power to autostart but the coupler may be gone if you are holding that pilot start button down for several min and the pilot light is still going out..ps.. leave it in pilot mode for several min after initial start up before turning turning full burner operation operation operation operation operation operation operation it will snuff out the pilot light.
May 18, 2016 | Water Heaters
I can get the pilot light to stay on but main gas burner won't fire up
If the pilot is lighting and the thermo couple is in the fire and turned red and the pilot still does not stary on change the thermo couple. They are available in any home improvment store.
Nov 04, 2014 | RTO Suburban Rv Water Heater Dsi Gas Valve...
It just stopped working last night. Gas kitchen stove works fine. Are there pilet lights on these things?
if its gas, it has a pilot light. the most likely thing is the thermal coupling is bad. if it is bad, burner flame will not turn on. it senses the tempurature to send gas to light burner.
Aug 06, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Pilot light will not automatically light when hot water is turned on
This is a great unit! Try turning the flow nob to the half way point and the flame all the way to low. Run the hot water tap and slowly turn the flame dial until you hear the unit try to light. Every house is different regarding the restrictions in the plumbing and water pressure. Once the unit tries to light that is your minimum setting. It is best to leave it there.
Apr 05, 2010 | Bosch & Tankless LP Hot Water Heater
Pilot light is on, but no hot water. thermostat is turned all the way up to HOT.
my gas hot water systems pilot light is on but yhe burners dont ignite when i put the hot water on,so in turn im not getting any hot water
Sep 09, 2009 | Rheem Water Heaters
Pilot lights (not always) but gas will not flow into burner
First Clean the ignitor assembly and make sure the flame is reaching the flame sensor strongly.
You may need to replace the flame sensor.
Sep 19, 2008 | Bosch 1600H-LP Liquid Propane AquaStar...
Water Heaters Logo
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
