Question about Vocopro UHF-5800 Professional Microphone
HOW DO YOU HOOK UP A VOCOPRO WIRLESS MICS 5800 AND A KUSTOM AMP 4080 AND WHAT CALBES DO I NEED
Hello. Where is the fuse located to be replaced in my Kustom KPM4060 Amp. Thanks Shawn.
I have the same problem with my KPM 4080 amp. I have no clue where the fuse goes. I'm sure mine also needs a fuse replaced.
Mar 11, 2015 | Kustom Music
I have a kustom kpm7200 that sounds distorted even at low levels.
That is like asking which grain of sand is red. Try checking your input levels, if they are to high this is exactly what you will get. Set all EQ settings to mid point. If the problem is not resolved take it to the tech for repair.
Mar 03, 2015 | Audio Players & Recorders
I have got a kustom KPC10mp and i am trying to hook it up to a kustom non- powered and i cant get no sound thru the monitor , Can this be done .The line out dont make no sound when it is connected to the...
In a word, NO. The line out is line level audio... it has NO power amp and cannot drive a non-powered speaker. I have both of these cabinets myself. You need to use an amp with the non-powered speaker. When using an external amp you will need to make sure you phase the two speakers correctely... you could just reverse the speaker leads of the non-powered one if needed.
Sep 11, 2011 | Kustom KPC10MP 10" Powered Monitor Speaker
I have a KPM 4080 mixer that has a blown 1A fuse. What would be the most common cause.
The most common cause of a fuse blowing is excess current... now what has/could cause that is impossible for us to diagnose remotely. Failure in the power amp would be prime suspect with power supply components a close second. Double check that fuse rating... if on 120 volts it sounds low... it would be right for 220 operation.
Jun 04, 2011 | Kustom KPM4080 PA Amplifier/Mixer
I get little sound out of the microphone spots onm my DA-X10Pro. I have a karaoke THE SINGING MACHINE. When I use my karaokee machine mic plug in the mic works fine...but any voice into the mic...
The mics on the singing machine are very low end mics and MAY not work on your other unit. The Voco has very sensitvie inputs to use with "professional" type microphones. The Singing machine mics are going to be fairly high output and likely to overload the voco inputs. Procure some professional mics like Shure, AKG, Sennheiser or others and don't forget to use a balanced to unbalanced adapter or cable on the mics.
Jan 06, 2011 | Vocopro DaX10pro
I trying to hook up an old record player to my Vocopro karaoke machine & I can't get any sound. What cables & where do I hook them
the record player should have a 2 sets of wires (one for power) and the other for left/right sound........you may need an adapter for this if there is no RCA plug in (if there is plug in AUX)
Aug 08, 2010 | Audio Players & Recorders
66 people viewed this question
Top Vocopro Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Vocopro Audio Player and Recorder Expert? Answer questions, earn points and help others
