Question about Maytag Washing Machines
I keep getting a error f21 code showing up and i cant wash my clothes because it does not wring out the clothes and leaves them wet and if i start irt over it does the same thing please help
  • 8,197 Answers
F21 or F02
  • Depending upon the type of Maytag washing machine, you may notice an "F21" or "F02" error code. An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
  • Good Luck
    Posted on Sep 01, 2010
    LG Intellowasher 7kg WD-1255FHB not draining properly
    try draining to a different place . my system does not drain into something that can get plugged with leaves
    Nov 01, 2017 | LG Washing Machines
    I got a F21 error, went through and pulled out the drain filter. And tried to start again continued getting F21 error. Bought a new water pump and still getting the F21, also backfilled some water into...
    sounds like you have covered all the bases --- the next thing that I would try is to simply unplug the unit from the wall and let is sit for a minute or two and then plug back in. if this does not solve your F21 code, then I would say that the problem is at the sensor or main circuit board.
    let me know if you need further help with this issue,
    c...
    Feb 03, 2011 | Kenmore HE2 Plus Front Load Washer
    Please help! My samsung 7kg J845 front loader keeps flashing UE on the error code (spin cycle) and I can't open the door. Sarah
    Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
    Oct 22, 2009 | Samsung WF337AA Front Load Washer
    Bosch Exxcel Washer F21 error code
    got a bosch washing manchine it keeps coming up f21 error and i have no book 2 see wot it is can you help me by tellin me wot it is thanks
    Apr 11, 2008 | Bosch Washing Machines
    Washing Machines Logo
    1,028 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
