Question about GE JBP70BK / JBP70WK Electric Kitchen Range
Can tin foil touching a electric oven burner element cause a failure? Someone just put tin foil in oven which is two years old and suddenly it failed.
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote because others had asked about aluminum foil and electric ovens...
Electric Oven Problems - What not to Use in Your Electric Oven
heatman101
Posted on Sep 01, 2010
Tin foil was melted to the top of one of my wife's and my electric stove burner coils. I was able to remove most of the foil but there is still some stuck to the burner and will not come off from scraping...
Use a fine grit sandpaper. Don't scrub too hard, you may scrub through the heating element. Take it slow and easy -- may take a while.
Charlie
Feb 05, 2011 | Microwave Ovens
My oven had a new heating element and a year later needs another is this average or is there a reason
Some elements are cheaper than others.
But,normally most can expect 5+ years or so.
Some last a year, some 10.
Also, make sure nothing is touching the element(like those aluminum catch pans, or tin foil ect.
Wigo.
Mar 04, 2010 | Ovens
Does putting tin foil on the bottom of the oven reduce the life of the element
No. That must be an old wives tale. Never heard of it. The problem with foil on the oven bottom is it gets covered with grease and may fire-up. Now on the other hand if your oven catches fire from grease build-up on the foil, well that will shorten the elements life and maybe yours.
Oct 17, 2009 | Force 10 Galley Range
I have a TEF326FB and the bottom heating element stopped working. Isn't this still under warrantee? How do I repair?
probably no warranty. tin foil lining usually causes it to burn out. with stove unplugged, remove the screws on the plate holding the burner. pull it out, remove two wires on the element (there may be a third one, green for ground) buy new one at any hardware store (cheaper) or from the manufacturer.
Jul 22, 2009 | Ovens
Melted tin foil on oven bottom
in your owners manuel is stated to not put tin foil on the bottom of the oven.. depending on your model you may be able to replace the bottom panel.. however you can still use the oven without any problems.
Jan 20, 2009 | Kenmore 30169 Electric Single Oven
Yes, we were a couple of dummys when we received our brand new LG stove, with convection oven,glass top and very fancy, and we put tin foil to cover the bottom of the stove and of course yesterday when I...
I really don't know what to tell you. During the clean cycyle the metal probably melted and is permantly sealed to the bottom. You are lucky the oven still works. Sometimes using foil will destroy sensors or other things. NEVER use foil in ANY oven!!!!! The only exception is to partially cover the shelf underneath something you know is going to make a mess. Even then don't cover more than about 60% of the rack.(Never do this in a convection oven as the fan will blow the foil ) Also NEVER!!! allow foil to come in contact with a hot burner. It will melt to the smooth top or coil.
Jul 07, 2008 | LG Kitchen Ranges
Melted Tin Foil in bottom of oven
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. The melted foil will not affect oven operation. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. The only option you have is to replace the panel (if replaceable) or the entire oven liner...
Jun 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. You should never place anything on the bottom of a stove that has a hidden element. You WILL damage the panel. The only option you have is to replace the panel or the entire oven liner...
May 20, 2008 | Ovens
Tin foil stuck to bottom of oven
if not a lot of foil get that easy off thats made for self cleaning ovens soak it let it sit then wipe make sure you get the one that says safe for silf cleaning dont scrape soak then after wipping off run self clean
Dec 27, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Use "The Works Toilet Bowl Cleaner" to dissolve the foil. *Caution* when the cleaner is applied to the foil a chemical reaction occurs releasing some harmful fumes so please use outside or in a well ventilated area. I just did this to a Frigidaire oven I bought from Lowes at a discounted price. The previous owners bought it, did not read the owners manual or just disregarded the warnings on using foil in the oven and thought they would line the bottom pan with foil to help make it easier to clean (Good idea, but don't try it on the hidden element ovens). With the heating element being hidden under the drip pan the heat is hot enough to melt the foil and fuse it to the pan. Now most of the pans on these ovens are removable by just a couple of screws and I strongly recommend removing the pan when doing this. Squirt some Works toilet bowl cleaner on it in a well ventilated area and watch it go to work. It took about 15 minutes for it to dissolve all the foil on my oven, then I rinsed it clean and reinstalled it in the oven. The pan does have a slight discoloration on it, not from the cleaner but from the foil being melted onto the pan, if you choose you can buff this out. Most of the modern ovens have the ceramic coated drip pans in them so the Works toilet bowl cleaner will not harm them, unless you have scratched the finish off. Works Toilet bowl cleaner contains a fair amount of hydrochloric acid which is what makes this work so well.
Oct 23, 2007 | Kenmore 33169 Gas Single Oven
GE JBP70BK / JBP70WK Electric Kitchen Range Logo
1,120 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
