Question about Fender Hot Rod Deluxe Guitar Combo Amplifier
Power wires from transformer to pc board were labeled but ink rubbed off! Can't remember where they go. Steve
  • Fender Master
  • 5,603 Answers
BLK to CP3 (hot power in)
WHT to CP4 (neutral power in)
RED to CP11 and CP12 (high voltage, probably 280VAC)
GRN to CP13 and CP14 (6.6VAC filament power)
BRN to CP15 and CP16 (about 38VAC bias supply)
If you email I can send you PDF of schematic.
Posted on Sep 01, 2010
Testimonial: "You guys are awesome! Just in time for the gig this weekend!"
Does a Yamaha clavinova clp 760 have a fuse that may need changing
There are a number of fuses on the main power board ( by transformer ) the sizes differ depending on the country of use but are clearly marked on the board.
REMEMBER TO UNPLUG FROM THE MAINS BEFORE OPENING - if in doubt seek the advice of a qualified electrician
Mar 07, 2015 | Yamaha Music
Need a power transformer for a Mackie 1202-VLZ mixer
The transformer itself will have the codes you need to replace it either printed on it or on a label stuck to it. Mouser should have what you need.
Sep 16, 2014 | Music
Djx 750 - no power - transformer dead?
Actually, you may be in luck. A burned cap means that it has done exactly what it's supposed to do. So...you might stick an identical one in there -- it's a 0.1 uF cap, and you can find these at Radio Shack (0.1 uF 50V) or online. They are cheap, so give it a shot.
Feb 16, 2014 | Behringer DJx700 5-Channel Pro DJ Mixer...
Fender G-DEC junior won;t power up the lights don;t come on it has a thermal cutout on the 12VAC transformer it was open circuit i tried bypassing it with soldered jumper still does not power...
Try changing out the Pico fuse. Only 50cents from online West Florida Components. Buy a few. Mine went out twice. It is Item # F021. It is a .5amp (500 mA)fuse-green and looks like a resistor. Location on the circuit board is near the transformer and on back edge or board behind the 2 brown wires connecting to the board and to the side of the 4 diodes there. I left the bad fuse in place and soldered the new fuse to it's legs-a lot easier and does not damage the PCB.
Oct 03, 2011 | Fender G-DEC Junior Modeling Guitar...
I recently got a Marshall mg100hdfx head for free because it wont turn on, so I am investigating possible parts that may need replacing. The only description I got as to why it wont turn on anymore is...
You may find almost anything in this. I think the power amp is on a separate board so the connections to that might have been broken. Possibility include cracks in the circuit board. First thing is to do after visual check is to check power supply voltages to verify power switch/fuse/transformer/rectifier/capacitor/regulator health. Switches are sometimes damaged... and also wires can fall of or break.
May 02, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
Hello my roland street cube won't power on, either with dc or batteries....adapter working .could a fuse be blown inside circuitboard? thanks
That is the first thing to check. They are most likely inside the circuit board. Remember to replace them with the same voltage and amperage ratings.
Feb 13, 2011 | Roland Cube-st Battery Powered Amp Cube...
My son has a Line 6 Spider III amp. The sound disappeared. I was told the problem is the power transformer had no power any longer. I need a 1X-5730-04H0 to replace the bad one. Where do I order from?...
Transformer failures are VERY UNCOMMON. I would verify the problem before trying to find one.
Most failures are with circuit board cracks and electrolytic capacitors.
Find a very competent electronic technician to check this out.
The RARE failures that occur in transformers are often poor soldering right near the terminals or lead wires. These can often be repaired without replacing.
Sep 29, 2010 | Line 6 Spider Iii 30
Yamaha CVP 309-When I power it up, red power light comes on, but
You have to remember that the voltages coming out of the power transformer are A.C. and the voltages used by the devices in the keyboard are D.C. Check for voltage rectifier I.C.s between the transformer and the rtest of the circuits. They should look like squares with 3 pins coming out of the bottom of them and metal backs that protrude above the top of the black squares. Use a volt ohm meter on direct current range and clip the black lead to a circuit ground such as a ground on an output jack. Touch each pin one at a time taking note of the voltage. If you find one that has the same voltage on all 3 pins it is probably shorted. I think the voltage should be about 12volts direct current positive or negative depending on the circuit. Each one will have a code that you can cross reference on the net to find the pinouts and specs. The same thing goes for all the I.C.s If you can find the pinouts for any that you suspect look for the power supply pins and check what the voltage is. Some will have two supplies, one negative and the other positive. If you find an I.C. with power at all pins or ones that should have no power only signal then it is likely shorted. Go slowly and don't bridge two pins at once by accident and you might be able to find the problem without the schematic or a service manual. There is a memory battery (CR2032) that power the memory that might be dead but that should only affect the programmed sounds not the LED or the amp chip. Hope this helps. Do not measure A.C. with the D.C. range or you'll burn out your meter. Use safety precautions with a live device.
Aug 10, 2009 | Music
SPEAKER OUTPUT CHANNEL FAULTY, TWO MIKE CHANNELS DOWN
These are a real pain to open. You have to remove the front panel to remove a shield to remove the back amplifier power supply area. The power supply is a switching type and has lethal voltages present. Working on this should be done using an isolation transformer. With your symptoms, it is likely one side of the power amp MAY be blown, but do check that the wiring hasn't fallen off and the jack itself. Two pairs of wires come from the power amp to the front panel jacks. document location of ALL the cables you disconnect as they CAN be confusing to restore.
May 13, 2009 | Fender Passport Deluxe 500watt Sound...
Problem with lights on the drum machine display.
It possibly is an open series resistor feeding the positive tap to all 3 positive regulators, but without specific knowledge of this machine, I can't be sure.
Aug 07, 2008 | Alesis Sr 16 Stereo Drum Machine
Fender Hot Rod Deluxe Guitar Combo Amplifier  Logo
205 people viewed this question
Top Fender Music Experts
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Are you a Fender Music Expert? Answer questions, earn points and help others
