Question about Achiever CCS5000 Shredder
WILL NOT START . LOOKED AT THE INSIDE AND AIRED ALL OUT WITH HIGH PRESSURE AIR. STILL NOTHING. WHAT DO YOU THINK I CAN DO? I HAVE CHANGED THE FUSE AND NOTHING THE UNIT TURNS AND NOTHING IS HANGING UP. PLEASE ANSWER.?????DR. BOYER
  • drjamesaboye Sep 02, 2010
    IT CAME ALIVE BUT WILL SHUT OFF OR NOT GO FOWARD , BUT BACKWARD WORKS FINE THEN WAIT FIVE MIN. THE UNIT WILL RUN AGAIN THEN SHUT OFF. IS THERE A TIMER OR HEAT ELEMENT ON THE MACHINE SINCE PREVIOUSLY I HAVE HAD NO PROBLEM. WHERE DO YOU GET A NEW MACHINE IF THIS ONE KEEPS ACING UP? DR. BOYER
  • drjamesaboye Sep 08, 2010
    THE UNIT STARTED WORKING , WHY I DO NOT KNOW EXCEPT THE FACT IT WORKS LIKE OLD TIMES THANK YOU, DR. JAMES A. BOYER
    Top Expert:
  • Achiever Master
  • 79,851 Answers
Most likely the safety switch is defective or the motor has failed
Posted on Sep 08, 2010
  • 19,396 Answers
Hi.
Check the interlock switch, which is the switch that closes the circuit when the upper part is removed. The switch is probably broken. Testing is done jumping the switch.
Parts for this unit are not available. If the switch is broken, then the only repair would be jumping the switch. This will make the shredder less safe. I suggest replacing the unit.
  • 2,973 Answers
Dr Boyer,
Any signs of life when you power it on? Like some light coming on or some click sound? If none, then check the wall socket and the plug for current. Check the power on switch. If they all are fine, check the connections to the motor. If the current is reaching the motor then it should run unless some paper is stuck or the motor is burnt.
Posted on Sep 01, 2010
My ssrxpe60 ingersoll rand compressor is giving a high air pressure alarm and shuts down
I may be missing something here but typically a SSR is a rotary screw machine.XPE 60 is the model. It probably has a controller of some type for this person to know its shutting down on high air pressure alarm. So as the previous person kindly said don't give advise on something you know nothing about before you get some one hurt or killed!!!!
To answer the question. You may have a pressure transducer bad but most likely you have a minimum pressure check valve stuck in the closed position. When the compressor starts air pressure in the separator tank builds. At approximately 65 Psi the MPCV opens and allows air to the after cooler and out into the system. If the MPCV doesn't open the air pressure in the separator tank becomes to high. You then get the high pressure alarm and the unit shuts down.
Make sure the air pressure is zero, electrical disconnected and discharge line isolated from system. Once done you should be able to unscrew the aluminum cap on the check valve. Be extra careful due to spring tension. It should loosen as the cap is removed. If the parts inside are very corroded or you are unable to remove the cap you may have to replace the complete valve. If able to disassemble clean and purchase a rebuild kit for your MPCV if available.
Feb 21, 2015 | Ingersoll Rand Air Tools & Compressors
I saw you answer regarding the fuses for AC on the Acura RDX 2008. My AC starting blowing hit air I tried to recharge it but it was full so I know that's not the problem . The pressure was high. The person...
More then likely the valve is open on the heater hose , there are two small hoses running from the engine radiator to the heater radiator , one has a valve or tap that is open to heat and closed when the air con is engaged, make sure it's not frozen open.
Jul 24, 2014 | Cars & Trucks
I left for three days and came home to an air conditioner that is not working. No fan, no anything. I checked fuse box. Nothing. It is only 3-4 years old. Any help?
First verify you have line voltage, then I would start with the transformer in the indoor unit, if its open nothing will come on
Aug 24, 2011 | Ruud UBHC Air Conditioner
I have a Bostitch RN46 Roofing nailer. I bought it used. I first tried it out hooked to a JacPac CO2 system that happened to malfunction at the moment I used it with the roofing nailer. The pressure on the...
The high pressure blew out one or more of your o-rings inside. The drive piston should not move freely in the gun so the o-ring around that is definitely one of them. It's hard to damage the metal and plastic parts of a gun short of dropping one off a roof so rebuilding one by replacing the o-rings is always worth it. You should look for a rebuild kit Part Number: RN46-RK
Nov 16, 2010 | Stanley Bostitch Rn461 Gun Coil Roofing...
Where is the inline air conditioner filter located
What you are referencing is probably the orifice tube + a screen.
There are many things that can change the air temperature inside the car.
1. Inside AC/HEATER duct under the dash, the temperature door can be open a bit and let the warm air mix with cold air temperature.
2.The purpose of the orifice tube, that is between the high pressure and low-pressure tube you can feel with your hands the cold and warm tube
The screen is blocking particles of metal from A/C compressor if the compressor is defect.
high-pressure side is HOT
low-pressure side is COLD
3. A/C compressor clutch could slip more than it should. The air gap has too much clearance.
The location of the orifice tube is :
New Orifice Tube EX 5151C 302272679 S10 Trailblazer Blazer DeVille eBay
To show you an example withdrawing and principle of A/C system and where to look for your question.
Hope it helps.
Feb 24, 2018 | 1992 Buick LeSabre
I live in an apartment that has Airtemp central air. The unit blower runs but the air is barely cool. Maintenance sys there is nothing wrong with the unit. What could cause this problem?
air temp should drop 15-20 F across the a/c coil a rule of thumb i use is air temp out of the vents 10-15 F less than room temp on thermostat if the air out of the vents isnt that cold the a/c is either leaking and undercharged or return air temps are to high. is the inside unit in an attic? return leakage in this situation can cause high supply air temps but look like every thing is ok when pressures are checked at the outside unit
Jun 15, 2010 | Heating & Cooling
Ingersoll Rand Air compressor loosing pressure
sounds like you have a problem with the discharge valve on the secondary cylinder, some I.R. pumps rely on the cylinder head valves to hold back tank pressure when the pump comes to a stop. the line down to the crankcase in front of the crank is a unloader valve that dumps the air pressure inside the pump to allow the next restart. I think that once you drain the tank and remove that cylinder head you will find a defective valve in the head.
Mar 24, 2010 | Ingersoll Rand Air Compressor Maintenance...
No high speed on fan for heat and air
Replace your high speed cooling fan relay with a known working relay (rear window defrost for instance) and see if the fans turn on while the air is on high. If so, you need a new relay. You can also look into the fuse that protects the relay circut.
Jul 06, 2009 | 1994 Oldsmobile Silhouette
Just replace the outside unit and added knew a frame coils inside, the ac is not keeping up with the heat. my old unit was a 3 ton and worked well, my new unit is a 3-1/2 ton and working non stop, what...
start with making sure you have aclean filter, after that make sure the blower speed is at the proper setting when the air conditioning is on---usually either high or medium high for a fixed speed system, make sure the return air vents are not blocked or restricted as well as the delivery vents not close or restricted to cause too much static pressure ( back pressure at the delivery side can reduce air flow across the a-coil ) also make sure the insulation sheet that is usually above the a-coil is not being blown down across the a-coil entryside when the blower is on. After checking all these, if you find nothing you should start by having the pressure checked --- basically comparing the pressure at the "outside unit" to the pressure at the "inside unit" or a-coil. these are high side and low side pressures. Have you done anything else to the house----attic vents, new soffits, insulation, etc that may be affecting heat gain in the house.Is it a house, mobile home or what?
Jun 22, 2009 | Coleman Propane Forced Air Heater...
High load and temperature in air compressor
The shut off and on is controled by the limit switch. There is contacts that springs pull down to contact there mating surfaces,the air builds up and over power the springs and lifts them up to shut off. So yours has maybe sparked enough to fuse together or someone has turned the adjusting nut which tightens the spring so it takes more air pressure to shut off. Make sure it is unpluged and remove the cover from the limit switch and look inside the cover for adjustmet instructions. Also check to see if the contact points are stuck together.
May 11, 2009 | Air Tools & Compressors
Achiever CCS5000 Shredder Logo
61 people viewed this question
Top Achiever Office Equipment & Supplies Experts
quennie732
ray gallant
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
