Question about Whirlpool Dryers
*my whirlpool dryer model LER4634EQ1,serial MG2203726,will not run and i was wondering how do i by pass the door switch and the push start button
    President:
  • 3,773 Answers
Just tape the two lid switch wires together and this bypasses the lid switch. Its not neccessary on start button
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 02, 2010
Ler7646 jqo whirlpool dryer
broken door switch,if the dryer hasn't been cleaned out and you changed out the thermal fuse could be one of the t-stats on the heater box,the model number you sent doesn't come up,
Ler7646jqo,open the door,you'll see a tag with the model and serial numbers,on the frame around the door opening.you'll need an ohms meter to check the parts,you have to remove at least one wire going to the part you're checking with the machine unplugged and check the part for continuity,if the dryer hasn't been cleaned out most likely the high limit thermostat on the heater box.if you don't clean out the dryer and vent line it will pop again until the dryer is cleaned,the dryer is running to hot from the lint blocking the air movement and the fuse pops as a safety device so you don't have a fire.
Feb 19, 2013 | Whirlpool LER4634J Electric Dryer
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dry won't start when button is pushed yes it has
Bad door switch, possibly. Wire slide connector on the door switch is loose, possibly. These are really simple to fix.
Apr 07, 2010 | Whirlpool WED5900S Electric Dryer
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
Dryer wont start - no lights
Dryer door does not think it is closed. There is a sensor on the top of the door that is probably not making contact with the door. Trying pushing the top part of the door and holding it then press the start button.. if the unit starts running then you know what it is. I just had one of these dryers delivered today and had to find out about this by myself tonight!!
Apr 30, 2009 | Whirlpool WED9500T Electric Dryer
Heating element heats up, but dryer will not spin.
Since you stated that the heating element is heating up I believe it rules out the thermal switches.
When you push the start button does it make the motor make any noise? Maybe hear the motor humming? Two things to check for are Broken Belt or Bad Motor:
This requires common sense and since you are going to be bypassing the safety features you need be CAREFUL.
First, with door open, manually press in door switch to by-pass door safety, then press "start", try to manually start the dryer by spinning the drum by hand, If you hear the motor humming but it does not start spinning on it's own; most likely it is a broken belt which can be changed without much difficulty for less than $15 bucks. NOW if it then continues to spin on it's own GET YOUR HAND OUT OF THERE and close the door; you have a bad motor and even though it started it needs to be replaced. A motor for that is available for just under $100 bucks and is not to bad to replace, I would recommend replacing the belt at the same time since you will be in there. Good Luck!
Apr 29, 2009 | Whirlpool LEQ7030KQ Electric Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
217 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
