I own a DVD/VCR GoVideo Player. The video on DVD mode does not work. THe tv screen displays ProgressiveScanMode. Everything else works fine. This started when I was using the remote to re-set the time. This is a DV 1130.
  • 4 more comments
  • gigihall May 09, 2008
    I cannot get the progressive scan mode off of the tv. I use the remote to try to change settings, and cannot. It is stuck! Can I turn it off and re-set it? Cross my fingers?!
  • gigihall May 18, 2008
    Does not work. G. Hall
    I have tried all of the suggestions that have come my way. Turning off equiptment ; turning it off it many different ways; buying a new AV cable. None of these suggestions have worked. G Hall
    PLease guys no more replys! I have done all you have suggested. AV cable included. I sincerely hope that with all of the time and running around to get these parts; that your billing dept. declines charge my credit card. G Hall
    NO more replies! Nothing works. Please do not charge my credit card. G Hall
    NO more replies G Hall Do not charge my credit card G Hall
    Genius:
  • 1,011 Answers
Hello Sir,
When DVD stop. Press P.scan it will ask Interlaced -> Progressive -> Progressive. U just press the Interlaced. Then it will become normal to play it. And u also Check NTSC/Pal mode to set changes. Check out.
A. How Traditional Video is Displayed
Normal video, such as from VHS VCRS, Camcorders, and television broadcasts, is displayed on your TV as a result of scanning series of lines on a screen surface in a format called interlaced scan. In this system, lines of video are displayed in an alternate fashion on a television screen. All the odd lines are scanned first, then all the even lines. These are referred to as fields. This process results in an interlaced image. Each frame on your screen is made up of the two interlaced fields of video. Although video frames are displayed every 30th of a second, the viewer, at any given point in time is only seeing half the image. Since the scanning process is so quick, the viewer's brain perceives the video image on the screen as a complete image.
The Difference Between Progressive Scan and Interlaced Scan
Progressive scan differs from interlaced scan in that the image is displayed on a screen by scanning each line (or row of pixels) in a sequential order rather than an alternate order, as is done with interlaced scan.
In other words, in progressive scan, the image lines (or pixel rows) are scanned in numerical order (1,2,3) down the screen from top to bottom, instead of in an alternate order (lines or rows 1,3,5, etc... followed by lines or rows 2,4,6). By progressively scanning the image onto a screen every 60th of a second rather than "interlacing" alternate lines every 30th of a second, a smoother, more detailed, image can be produced on the screen that is perfectly suited for viewing fine details, such as text, and is also less susceptible to interlace flicker.
Video is another issue which continues to present most problems. Current players typically output analog video only, both composite video on an RCA jack, as well as S-Video in the standard connector. However neither of these connectors were intended to be used for progressive video, so yet another set of connectors has started to appear, to carry a form of component video, which keeps the three components of the video, one luminance signal and two color difference signal, as stored on the DVD itself, on fully separate wires (whereas S-Video uses two wires, uniting and degrading the two color signals, and composite only one, uniting and degrading all three signals). The connectors are further confused by using a number of different physical connectors on different player models, RCA or BNC, as well as using VGA cables in a non-standard way (VGA is normally analog RGB—a different, incompatible form of component video). Even worse, there are often two sets of component outputs, one carrying interlaced video, and the other progressive.
In Europe (but not most other PAL areas), SCART connectors are typically used, which can carry composite, Y/C (S-Video) and/or analog RGB interlaced video signals (RGB can be progressive, but not all DVD players and displays support this mode), as well as analog two-channel sound on a single convenient multiwire cable. The analog RGB component signal offers video quality which is superior to S-Video and identical to YPbPr component video. However, analog RGB and S-Video signals can not be carried simultaneously, due to each using the same pins for different uses, and displays often must be manually configured as to the input signal, since no switching mode exists for S-Video. (A switching mode does exist to indicate whether composite or RGB is being used.) Some DVD players and set-top boxes offer YPbPr component video signals over the wires in the SCART connector intended for RGB, though this violates the official specification and manual configuration is again necessary. (Hypothetically, unlike RGB component, YPbPr component signals and S-Video Y/C signals could both be sent over the wire simultaneously, since they share the luminance (Y) component.)
Don't forget to rate the solution
Posted on May 09, 2008
    Genius:
  • 3,422 Answers
Try resting your player.CLICK HERE for the manual.Once you reset it will restore the factory default settings.
Goodluck,
Please don't forget to rate the solution
  • Priya darshan May 10, 2008
    Ok,then try a hard rest by unpluging all the cords for 30min and then put them back all.
    Goodluck..
  • 3,037 Answers
Push stop on remote to stop a DVD from playing. Push and hold stop for 5 seconds. If this doesn't work, try unplugging it for 5 minutes to reset it, let me know if neither options work and we can try a few other things.
Thanks
  • 2 more comments
  • Benjamin Patri
    Benjamin Patri May 09, 2008
    you can also try holding stop on the player itself if the remote doesn't do it.
  • Benjamin Patri
    Benjamin Patri May 10, 2008
    yes, you can try turning it off for 10 min to reset it, I would also try pressing the stop button on the device itself
  • Benjamin Patri
    Benjamin Patri May 11, 2008
    Please don't forget to let me know your thoughts about my solution.
    If your problem is fixed, please rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
  • Benjamin Patri
    Benjamin Patri May 18, 2008
    Please let me know if you have any further questions so I can get you on your way.
    If not, then don't forget to rate my solution as any feedback is appreciated.
    Thanks, and have a good day.
    Sergeant:
    Champion:
  • 256 Answers
Is your DVD/VCR works on AV check sitting on AV or replace AV cable....
I have a go video vcr/dvd player. The vcr works dvd doesn't
if this happens to all discs needs to be repaired.my panasonic was playing up and not very old,and cost me $350.00 for a new driver.
Jan 03, 2010 | GoVideo Go Video DVD/VCR Combo
Can't turn on my go video dvd/vcr player, keeps
Unplug it, press the power button, then plug it in and retry it. If it doesn't work, unplug it, press power, and let it sit a couple days, to try to reset everything. There may be a reset pinhole in the back, unplug it and press the reset button.
Sep 15, 2009 | GoVideo Go Video DVD/VCR Combo
Setup Menu will not display on TV screen
Ok, on the back of the unit, there is a single yellow composite output. There may also be a Red, green,blue.Component. Take 1 RCA cable and plug it into that yellow output, and route it into your TV input, also a yellow composite. Make sure that whatever input you put that into on the tv, that you change the TV input to that to view your player. when and if you get a picture, you should be able to get to the menu through the GOVID remote.
Later once that Path is working, you can upgrade it to the Red,. green, blue, if your TV has the inputs. You did not give a model for the TV or I could tell you what it has.
If you need any more clarification, please reply.
Best Regards,
Charles
Jan 05, 2009 | GoVideo Go Video DVD/VCR Combo
GoVideo DVD combo
Hi - I can record a dvd from the tv and can play it back but when I try to play a store purchased dvd it ejects the dvd and on the tv screen it says unknown disk, please, check disk again.
Aug 19, 2008 | GoVideo Go Video DVD/VCR Combo
Sound problems
TRY PUTTING A SET OF PHONO CABLES INTO THE VCR INPUT THEN TO THE ANALOG OUT PUTS ON TOUR DVD/VCR SWITCH AMP TO VCR PRESS DIGITAL INPUT BUTTON ON FRONT OF AMP UNTILL YOU GET _ _ _ SET SOUND TO PROLOGIC 2.THIS SHOULD WORK.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Onkyo TX-SR605 Receiver
GO VIDEO DVD/VCR PLAYER
I recently purchased a new flat screen TV a Samsung that has a remote that can be configured for all of your devices the manual for the TV has a list of codes that you have to put in so the remote can work with them. They have a code for a VCR player and some codes for a DVD player separate but not a code for a combo DVD/VCR player. I have hooked up another DVD player that I have and the procedure to set it up works fine and I have contacted Samsung and all the connections are correct do you possibly know if there is a different code for the combo units.
Thanks,
Robert Moore
Mar 22, 2008 | GoVideo Go Video DVD/VCR Combo
DVD/VCR combo player won't work
I had a similar problem and corrected it with a solution found on another site. Try hitting the I/P button on the remote which controls whether "Interlaced" or "Progressive Scan" is used to display the image on the TV. Mine worked when "Interlaced" was used. but no picture was displayed when "Progressive Scan" was used. The I/P button toggles between the two settings.
Dec 19, 2006 | Apex Digital ADV3800 DVD Player/VCR
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
