Question about Samsung WF206ANS Front Load Washer
I have a front louder newer model samsung washing machine. The door was forced opened during cycle and now the lock is still in the locked position and I cannot reclose the door or get the locked to unlock so the door can be closed.
  • Samsung Master
  • 17,129 Answers
The machine has to reset to bringg tthe lock to release, check the link to the lock settings to make the program complete the cycle and release the lock. Do not force it as you end up damaging.
Posted on Sep 01, 2010
I load the clothes into the washing machine, I turn it on select cycle and the door locks and will NOT unlock. The door will however unlock after the cycle is finished.
Not sure if you're unable to open the door AFTER you stop the cycle. That may be normal operation as a safety measure (won't open until after your cycle has completed). However, if your model DOES allow for opening the door during cycle operations then your electronic door lock may be defective.
Mar 08, 2011 | LG WM-2277HW Front Load Washer
I was using the spin cycle to spin water from a scarf. I decided to stop the stop so I hit cancel button. Now the washer door is locked and I can't open it.
• If the cycle is interrupted during spin, it will take approximately 2-3 minutes for the door lock to release. DO NOT force open the door. • To stop the washer, press Cancel.
Jan 05, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have a frigidaire affinity front loader washer that the final spin cycle won't work on. The rest of the wash cycle is fine and the basket spins for the other cycles just not the spin cycle. It is also...
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies that the auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to address the issue.
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine. Disconnect the electrical connections then connect it to the new door lock and switch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop.
Jul 13, 2010 | Frigidaire ATF6000ES Front Load Washer
My lg door will not unlock
this kind of door lock is called PTC door lock.It is designed for protecing you from opening the dooe during the washing and spining cycles which may hurt you.So, if you want to open the dooe during cycles,pls press "stop",then ,wait 2 mins,you will be able to open it by then.the other situation is that,the power is cut off during working cycles,solution is:re-start the washer and directly open the door.Pls note that this kind of lock has to work under power
Mar 14, 2010 | LG WD-12126RD Front Load Washer / Dryer
Washer loader door is locked and i cant open it
this kind of door lock is called PTC door lock.It is designed for protecing you from opening the dooe during the washing and spining cycles which may hurt you.So, if you want to open the dooe during cycles,pls press "stop",then ,wait 2 mins,you will be able to open it by then.the other situation is that,the power is cut off during working cycles,solution is:re-start the washer and directly open the door.Pls note that this kind of lock has to work under power.
Mar 14, 2010 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Door lock is locked but door is open
take the kickplate of the machine of and put your hand iside by the door lock , fill a round tab there just pull and the door is going to unlock
Jun 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
HE front loader washer door opened during cycle and will not shut
the latch broke within( the hook inwhich actually hold doorshut) , youll need a new latch assy.
Mar 14, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Maytag Model # MAH4000AWW Neptune Front Load Washer Problem: Door will not lock. All cycles during wash work except the spin cycle.
Clean out your filter after ref. to user's manual. Try some WD40 on the door mechanism (on machine), lock & unlock door 5 or 6 times while machine is off.
May 10, 2008 | Washing Machines
Washer load became imbalanced and forced door open, now cannot close door, lock stuck and washer will not run
Perhaps you have to change your lock, this is a sensitive point & will affect the smooth operation of your machine. Re. the inbalance, you hv to screw up & lock the front 2 legs (with check nut), adjust the front legs (screwed up) only to see if the machine does not move during wash/spin.
Nov 13, 2007 | GE WBVH6240F Front Load Washer
Samsung WF206ANS Front Load Washer Logo
608 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
easy alberta
easy alberta
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
