Question about IBM ThinkPad T60 Notebook
Laptop CPU hi. i have a laptop and my cpu fan is getting really loud and it seem to be getting hotter than it used to. i was wondering if this means its about to give out on me, keep in mind its less than 2yrs old
  • wahidr Aug 15, 2008
    I have problem with my notebook T60 IBM the fan is giving noise slowly but seem increasing day by day this is happening since a week now I tried to vakcum the fan but still its making noise could anybody please assist me.
    many thanks in advance
    wahid
    wahid.rasuli@hotmail.com
  • IBM Master
  • 13,433 Answers
*There can be alot of dust inside the fan ducts and it has to blow harder to get the air flowing. I recommend you clean the cooling system.
Compressed air + vacuum cleaner
blow the compressed air from the other end while the laptop is turned off and have the vacuum on low / medium in the other end sucking the dust so it wont fly all over the room.
also another way is to take the laptop apart and clean the parts.
Posted on May 09, 2008
  • Ekse May 09, 2008
    with electronics never use anything wet to clean it.
Laptop crashed
Really need more information, but my guess is dirty fan. If fan is blocked by dust, it may make noise and may run at high speed all the time because the CPU is overheating. If CPU gets hot enough, the laptop will shut itself down without warning. If dust is the problem, get some canned air. Before blowing into the air vents, try to spot where the CPU fan is and gently insert a toothpick to block the fan and prevent it from turning. A long blast of compressed air can spin the fan too fast and burn out its delicate bearings. Blow air from underneath and also from the side vent until air blows clear. In some bad cases of dust, the bottom or top cover must be removed to get it all out.
Sep 25, 2013 | Dell Vostro Computers & Internet
Asus x50sr fan on full constantly
That laptop have no to much space to get the air , and when the cpu get hotter , the cooler starts to go faster and than he make noise to much , watch the cooler , take off the dust , and take care of the cpu .
Oct 20, 2012 | Computers & Internet
Hi. I suddenly started hearing a whirring sound from inside my HP 6530b. And I think because of it my laptop seems hotter on the surface. Is it a fan not working correctly? What could that be? Thanks..
1.Check in your bios what your CPU and GPU temperature is.
2. make sure you have no CD or DVD in your drive.... as if it can't read this you will get a hot DVD drive !!
3. if you CPU or GPU temp is up .... you will possibly have a seizing bush on your internal cooling fan.
Hope this helps
Feb 10, 2011 | HP Business Notebook 6530b
My computer runs constantly its loud and annoying
I assume you mean the cooling fan on the CPU, this model uses a smart fan technology, it is meant to spin up faster to provide cooling. If is is doing tis constantly, it means the CPU is not getting adequate cooling (overheating), to check this, remove the side panel, clean all the dust and debris build up from the cooling fan and see if that helps
Jan 22, 2011 | HP Pavilion a1000n (PS567AA) PC Desktop
Reving,loud
Restart your computer -- there may be some "run-away" program on your computer that is working the CPU to its maximum.
Also, there are some heat-sensors inside your computer, i.e., the hotter that the inside of your computer is, the faster that the fans will run.
Check that the fan on top of the CPU is still working -- if not, your CPU will generate a *LOT* of heat.
Also, turn the computer off, and take a can of compressed air, and give your computer a "blow-job" to remove all the dust from inside your computer -- dust makes a great insulation, thus making your computer run "hotter" (and making the fans work harder/louder).
May 29, 2010 | Dell XPS 200 PC Desktop
Fan runs all the time and is loud. Sometimes by tilting the unit the fan changes pitches. Laptop is used on a table and airflow seems adequate.
Based on the information you provided there could be couple of reasons atleast: 1) Looks like the fan is having issues and needs to be replaced. 2) There is some CPU intensive programs (or background program . a virus?) running in the background.
You may want to run the Antivirus scan once to check for some unwanted background programs.
If it doesn't solve the issue, then probably the fan needs replacing.
Thanks and do tell if it did solve your problem.
Feb 10, 2010 | Computers & Internet
Today i started up my Asus N50V Laptop up and the fan is running continually now, I rebooted it and still no change. It never has done this before?
It is normal for the fan to kick in to cool the processor, but it sounds to me like the CPU fan and the air vents need a good cleaning.
Noisy fans and them running for a length of time means that its having to be on more to keep the processor cool.
Other causes of the fan being loud and on constantly is gaming and heavy programs. The more the processor has to work the hotter it will get, thus the fan being on all the time.
Have a look at your air vents and the CPU fan for dust. If you see any dust then you will need a can of compressed air to blast through the vents and CPU fan blades free of dust.
Removing the dust from the machine usually quietens them down.
Regards.
Nov 16, 2009 | ASUS N50Vn Notebook
My fan runs extremely loud on and off
It is set up to run if CPU gets warm/hot. Quiet normal.
If it didn't you would son know. One Cooked CPU with Chips. Expensive tak Away.
Some fans are noisey. You could go to the expense and have a replacement???
Nov 16, 2009 | HP Pavilion dv2915nr Notebook
My sony vaio VGN-CS11S is soo noisy
The fan's bearings are probably going bad, or there may be some object that was sucked in to cause the noise.
Sep 28, 2009 | Sony CPU FAN CPU Fan
My laptop turns on and then it turns right off!!! HELP!
hi there
It seems your laptop computer is not cooled properly which might be beacuse of a broken cpu fan as you mentioned it makes loud noise.
The reason your laptop turns off by itself is because theres a circuitry built on the motherboard which power offs itself if the internal temperature raises, this is a safety feature to prevent your computer getting burnt.
Please avoid using your computer and take it to a shop where you can have it checked for cooling.
hope this answers your question
May 30, 2008 | HP Pavilion dv1000 Notebook
IBM ThinkPad T60 Notebook Logo
76 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
