Question about Garmin Nuvi 660 GPS Receiver
The screen is freezing, and then the battery indicator has a lightning bolt looking thing through it. bad battery? reset?
  • Garmin Master
  • 2,130 Answers
The lightning bolt means the battery is being charged. Remove the charger and you will see that go away. As far as freezing, you might have a bad touchscreen. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Sep 03, 2010
What does a Nuvii 55 LM screen green icon with lightning bolt mean ?
The lightning bolt indicates that the battery is being charged. Remove the unit from the charger and the lightning bolt will go away.
Feb 07, 2016 | Garmin nuvi 55LM 5" GPS with Lifetime Map...
Show charging symbols
Your question was posted under the Nuvi 680 GPS, so I am assuming this is the model that you have.
On the main screen, you will see a green battery status indicator in the upper right-hand corner of the screen. The battery is divided into 4 parts. Each part represents 1/4 power. So if you have one green bar, that indicates that the battery has 1/4 of power left. If there are 3 bars, that indicates that there is 3/4 power left.
When the unit is charging, you will see a yellow lightning bolt appear over the green battery status icon.
When the lightning bolt is not there, this means the unit is running off of the battery.
When leaving the unit to charge, press and hold the power button until you see that the screen says Charging Battery. A few seconds later, the screen will go blank to save energy.
Pressing the screen again later will either say Charging Battery or Battery Charge Complete.
Mar 26, 2013 | Garmin Nuvi 680 GPS Receiver
Typrice never helped with my flash problem, I need help.
Is your battery fully charged? It's not an old battery on its last legs, is it?
Dec 20, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
My flash does not seem to be working, I tried just about everything but it wont work. it all started when I pressed reset im pretty sure, but im not postive. please help me.
Pressing reset would not disable your flash. On the screen, does a lightning bolt icon appear? Is there a letter A or the word auto next to it? Or does the lightning bolt have a diagonal line through it? In any case, press the button on the back of your camera with the picture of the lightning bolt until the lightning bolt with "A" or "auto" appears next to it on the screen.
How do i fix a zire 21 palm it wont turn on, charge,work nothing
Hello.
From Palm support:
1. Press either the Date Book or Address Book button to see if
you can turn on your handheld that way.
2. Perform a soft reset: Use the tip of an unfolded paper clip
(or similar object without a sharp tip) to gently press the
reset button inside the hole on the back panel of your
handheld.
3. Make sure the power adapter is plugged securely into a
working electric outlet and is firmly connected to the
handheld. (If no outlet is available, your handheld can also
be charged through the USB cable, but this takes much
longer.)
Note: Your handheld does not have an indicator light to indicate that your handheld is being charged.
4. Charge for another three full hours.
5. If your handheld now turns on, check the charging-battery icon to ensure that your handheld is being charged. Example:
a. Connect the handheld to an outlet and turn it on.
b. Tap Home .
c. Look for the lightning bolt on the battery icon at the top of the screen.
d. If you do not see the lightning bolt, repeat steps 3 and 4.
Hope this helps.
Nov 03, 2009 | Palm Zire 21 P80730US Handheld
No problem? ?? HP dv8230 status indicator lights flashing.
I believe this would mean that your battery either has a low charge or if you have the AC power cord plugged in, it could mean your battery is bad and won't take a charge
Jan 05, 2009 | HP Pavilion dv8230us Notebook
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
New battery on used phone won't charge
The battery might be bad you can go and have someone check the battery at any electronic store with a voltage meter.
Apr 22, 2008 | Palm Treo 700w Smartphone
Turning off the flash
This camera has four flash modes and each time you press the button the mode changes. As you press the button you should see the indictor in the upper left side of the screen.
1. In automatic flash, the camera will decide if you need flash or not. This mode does not have any indicator on the screen
2. Forced flash, this will cause the flash to be constantly on. The indicator looks (kind of) like a lightning bolt.
3. Slow Syncro, this mode slightly delays the flash and is used to lighten up the background more the foreground. The indicator looks like the lightning bolt with SL next to it.
4. No flash, this will turn off the flash. The indicator looks like a lightning bolt enclosed by a circle with a diagonal line through the lightning bolt. (similar to a no parking sign).
The mode you want is the circle and diagonal slash over the top of the lightning bolt.
If you don’t see the indictor changing on the screen the switch behind the button is malfunctioning.
Dec 27, 2007 | Sony Cyber-Shot DSC-P52 Digital Camera
Flash is not working ??????????????
Nov 26, 2007 | Sony Cyber-Shot DSC-P52 Digital Camera
Garmin Nuvi 660 GPS Receiver Logo
151 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
