Question about Latte Communications DT100 Bluetooth Headset
I have a Latte dt 100. It no longer lights up when I plug it in to charge, and does not charge. Is the battery just dead? Can it be replaced or repaired? Thanks,
My kindle fire does not keep its charge. I can use it one time and during the ap it goes dead
If you charge the device fully, meaning 100%, and while using it with a simple app it doesn't last 2 hrs. then you need to replace the battery. Next time it goes dead, don't turn it on, instead plug the charger and let it charge to 100% while the device is off. Once is fully charge, use it as you would normally do. But still,it needs a new battery.
Apr 30, 2015 | Tablets & eReaders
PSP Orange light when charging but battery wont charge
Your Battery may have developed dead cells and is no longer capable of charging.
Replace battery with new one
Jun 28, 2013 | Sony PlayStation Portable (PSP) Console
Satellite M205 S4804 Problem
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Jan 27, 2013 | Toshiba Satellite Computers & Internet
Samsung N145 Plus battery charge failure
Sep 03, 2012 | Samsung Computers & Internet
C640 compltely dead
POWER SUPPLY & BATTERY PROBLEM
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
May 21, 2012 | Dell Latitude C640 Notebook
My latte espresso battery keeps dying to fast when it's an 8gb and suppose 2 last for 6-7hrs but it only lasts about 3mins can somebody please tell me what to do!!!!!!!!!!!!!
Ifthe rechargeable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 01, 2011 | Bell Technology Latte Communications Ice ...
My laptop won't charge
You may have a dead cell in the battery try replacing the battery this is often the case. Good luck..
Dec 29, 2009 | Toshiba Satellite U205 Notebook
HP PAVILLION DV6000 REPORTS BATTERY NOT CHARGING
Your battery is dead when it no longer will hold a charge. Replace your battery.
Jun 02, 2009 | HP Pavilion dv6000z Notebook
Dell latitude D600 battery charge light flashing
I had the same problem, I removed the bettery while it was still plugged in, tested it, then plugged it back and and now all is fine.
Nov 02, 2007 | Dell Latitude D600 Notebook
Latte Communications DT100 Bluetooth Headset Logo
23 people viewed this question
Top Latte Communications Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Latte Communications Radio Communication Expert? Answer questions, earn points and help others
