Question about Whirlpool Refrigerators
I have a Whirlpool GS6NBE/GF6NFE that has been leaking water from underneath. I started keeping record of the leaking in Jan 2010. The leaks were occurring approx every two weeks, started occurring more often and this month has leaked on the 8th, 12th, 13th, 17th, 22nd, 28th and tonight, the 31st. One appliance repairman investigated a couple of months ago and could find no problem. Water is not coming from the drain pan. Drain pan looks as though never been wet.
the dr
  • 447 Answers
SOURCE: Water leaking frigidaire frs23h5as
yes remove the rear panel in the freezer where you see the drain hole. Clear the ice from the drain hole. It will take a while for the water to start to drain because the ice is deep in the insulation. A small tube is helpful to draw some hot water in and stick in in the drain hole and squirt the hot water down in the hole.
Posted on Nov 25, 2007
peyton32034
  • 410 Answers
SOURCE: drain pan leaking?
there is a drip pan located underneath you ref but most likely your prob is a plugged drain line coming from the freezer. when you ref goes into automatic def the water doesnt run out into the drip pan but instead onto your floor..
you can clean the drain line by removing the rear cover in the freezer compartment and using hot water to thaw the drain below the evap coil.
Posted on Dec 12, 2007
fridgetech
  • 473 Answers
SOURCE: Kitchenaid Superba 42 Refrigerator Leak under Freezer when Water Used from Door
Either the water filter isn't seated properly or there is a crack in the tubing or the water line isn't seated properly in the coupling behind the grill at the freezer door. Also, inspect for breakage in the line in this area as well (coupling area).
Posted on Dec 26, 2007
  • 198 Answers
SOURCE: Water Dispensor leak on Whirlpool Refridgerator
The solenoid valve needs replacing, located at the back of the refrigerator. If you have well water you will need to install a filter on the supply line.
Posted on Jan 05, 2009
bozcro
  • 867 Answers
SOURCE: A small amount of water is leaking out of the
older fridges drained water into a pan with the compressor in it, thus cooling the compressor and evaporating the water, this is located at the bottom back of the fridge. if this fridge has a water and/or ice dispensor, the water could be leaking from many a place.
Posted on Sep 14, 2009
Testimonial: "Thanks, I will check it out and see if I can find the pan. Have had trouble with the ice maker leaking before but this seemed different."
Water Leaks Underneath
You really need too look underneath and see where water is coming from that means raising the machine off floor washing machine quite heavy so need to know what your doing
Nov 09, 2015 | Whirlpool WFW9050XW Washer Front Load...
Water leaking out from underneath
How to Fix a Leaking Dishwasher Hose. *. Whirlpool Dishwasher Connection ... the drain hose pushes water from the dishwasher without water buildup ...www.ehow.com/how_12089937_fix-whirlpool-dishwasher-leaks-underneath.html
hope this will help
Jan 31, 2012 | Whirlpool Dishwashers
Drain Pan fills and overflows. Cannot get to drain pan to empty. Why the water and how do I get to the drain pan ? Also the refrigirator door maes a loud sound when It's opened and closed. It seems to...
The water is normal....however the evap motor and fan should be drying the water before it overflows. THe evap fan motor may need replaced. You will have to pull the unit from the wall and take the back panel off or tilt the unit back towards the wall and go in from the underneath side. As far as the door goes....you might need to tighten or replace one of the hinges.
Sep 01, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool refrigerator 166007 EBXVQ9SHK Frequent leaks. This is my third repair and every time, the repair dept said it is fixed but then it starts leaking again. The refrigerator was purchased from...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 11, 2011 | Whirlpool Refrigerators
My Whirlpool Gold leaking water
the water pump is bad, call a repairman usually only 75 to 85 bucks depending on where you live
Mar 01, 2010 | Whirlpool Washing Machines
Ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Oct 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water is leaking really badly underneath my Whirlpool refigerator.
I had this problem. Check you water line leading to your ice maker. the plastic section of it running up into the freezer cracks and leaks. easy fix, replace the tubing if it's leaking.
Jul 12, 2009 | Whirlpool Refrigerators
Ice maker making little ice/Leaking water on floor.
The ice trays bust be cleaned to prevent calcium build up. This will prevent the ice from froming in trays.
The overflow could be caused by the freezer not being level, or by the water fill timer not shutting of the incoming water. This will keep the water temp. too high to freeze the water. Also check the fill valve for sepage.
Feb 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking from underneath after washer drains
Hiya........... have a good look at the door seal for any visible tears... do it with wet hands... and the electric off!! If you cant see anything... Have a look at the pump couplings.. for any visible signs if leaking!
Get back with the results
regards Faggly
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a kenmore washer that is leaking bad underneath in the front making puddles of water. Im constantly keeping towels down everytime I wash a load. Could you please tell me what might be wrong? Thank...
Check the front door boot first. Make sure that there are no tears in it.
Remove the back of the washer, start a fill cycle and observe outer tub sections and hoses for leaks. This is a good place to start.
Jan 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Refrigerators Logo
104 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
