Question about Sony Televison & Video
My tv, Sony Trinitron Model KV-34HS420 does not turn on when I press the power bottom, only the "Stand by Timer" light located in front of the unit starts blinking.
  • jscintron4 Sep 01, 2010
    Good Night
    The "Stand by Timer" light blinks 6 times and then pause.
  • 10,594 Answers
Blinking of standby/timer light is ab error code that will give info about what section of tv got trouble for some reason.
That light would be blinking in specific order with 3 seconds long pause so count its blinking after pause to next pause and let me know to diagnose possible cause of problem.
Thanks.
Posted on Sep 01, 2010
  • Shahid Electronics
    Shahid Electronics Sep 01, 2010
    OK, 6 times blink error code shows problem with following sections
    1- +5 line is overloaded. (AY, BY, MY Boards)
    2- +5 line is shorted. (AY, BY, MY Boards.)
    3- IC504 is faulty. (AY Board)
    I'm not sure how handy person you are or you have prior experience of electronics stuff fix, so if you feel uncomfortable working in tv circuit boards, call local tv repairman and ask him to check above said boards and replace defective board.
    Let me know if you have additional question.
    Thanks.
    Did you get 6 times blinking light error details?
SONY TV. STANBY TIMER FLASHING
Hi Frank,
Please let me know if it has a pattern of blinks (separated by a pause) or it will flash an exact number of times. Your unit (KV-34HS420) has a built in self diagnostic software that will indicate the probable caused of the fault by flashing of the LED at the front panel.
Jdvillanueva
Nov 30, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Stand by
I have the indentical tv and problem. Cost to repair was about 250.
Aug 19, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I can't figure out how to get my Sony KV-34HS420 to factory settings!
Hello
To reset your tv to factory settings do the following:
1 Press POWER to turn on the TV.
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
OK
Jan 23, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Have Sony KV-34HS420 with no picture or sound. Timer/Stand By light flashes 7 times with pause in between. What is the likely problem and cost to repair?
Hold hair dryer to back right side on high heat for a couple of seconds while you hit the power button several times. It only took 2 times for my set to power on. Good Luck!
Aug 12, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
The light on the front of my Sony Wega the stand by timer and I get some sound for a few seconds then the T.V goes off. What is going on?
check your power supply or line transformer sections. you are having variations of power and leter semi conductors go into saturation.
i have mentioned a line transformer because before a line transforfer there is a transistor, which makes a transformer to oscillate, and later a transformer will give out so many dc voltages.
Mar 17, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV-34HS420 Random Shut downs
i would say this is a internal problem how long have you had it?
May 28, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
normally this is because of a failed capacitor or two that is located on the power supply board. replacing the power board in this unit will fix this issue.
Mar 16, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony wega trinitron KV-34HS420
did a quick google got this:
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/?page=6
blinking is the self diagnosis working.
Aug 27, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
122 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
