Question about Refrigerators
At least once a day my whirlpool 3 door freezer on bottom, 1 month old, gets very noisy like a bearing or fan out of balance
    Genius:
  • 1,073 Answers
Sounds like a fan motor in the freezer issue, it is under waranty, call whirlpool for factory service on the machine
Posted on May 09, 2008
Noisy fan stops when I open my freezer
Some refrigerators control the freezer fan by turning it off when the door is open to minimize cold air loss. This is likely normal for your model (check wiring diagram to ascertain this.) The freezer fan is the noisiest component on a refrigerator so the noise might be typical of your model. If it is excessively noisy (it's louder now than it used to be) then it will probably be one of the following: 1) bad fan motor bearings and the motor should be replaced, 2) loose or broken fan blade and should be replaced, or 3) frost/ice buildup on the evaporator (cooling) coil that the fan blade hits and the cause of the frost /ice should be corrected (likely a defrost problem.)
Oct 10, 2014 | Refrigerators
We have a fourteen month old Whirlpool ARC900 4.38CF. Motor is very noisy and doesn't cut out. Fridge not cold inside, so food gone off. Outside front door gets cold.
Good day,
The machine has 3 motors. The fan motor behind the rear panel in the freezer and a condenser fan motor located near the compressor that cools the compressor. If one of those 2 are an issue you should be able to change the bad one. It's pretty much a nuts and bolts job.
However, if it's the compressor, leave it alone. It carries a 5 year warranty. Call your selling dealer and schedule a warranty service call.
Nov 10, 2010 | Refrigerators
My Whirlpool refrigerator builds up ice in the freezer around where the cold air comes from. Eventually it starts to fill the bottom of the freezer with clear ice. It has done this almost from since it was...
you should manually defrost fridge/freezers every 6 months for optimum performance.also fill any spare capacity with clean waste foam, cuts down on all that cold air dropping the floor/warm air filling void (i put foam in plastic bags. works for me
Feb 08, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool model ED5FHAXSLOO refrig 3 years old very noisy
If it is cooing fine, then the noise is probably your evaporator fan (the one inside your freezer). This can be cause by one of several things. The motor on this fan may be going bad, or, more likely, you may have a build up of ice around the blades that are touching the fan. This may be caused by a defrost circuit that has gone bad, or, the freezer may have been open alot lately and there is an excess of frost that hasn't melted away yet. If you can, manually defrost the freezer and see if it goes away. If it doesn't, it's probably the fan motor. If it does, and then comes back, it's probably the defrost circuit. Hope this helps!
Dec 06, 2009 | Whirlpool ED5FHEXMQ Side by Side...
3 month whirlpool refrig. whole system seems to be shutting down.
You most likely have a bad pc board. If I were you I would call Whirlpool and have them send a technician out and fix it under warranty. The number should be on your paper work that came with unit. If not, call 1-800-555-1212 and ask for the number. I could try to help fix but if you mess with it, the warranty will be voided.
Oct 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kelvinator Single Door Hardening Cabinet Flash Freezer fan
If the fan motor shaft is smooth with 1 flat spot the hub on the blade probably has a hex set screw that can be tightned with an allen wrench. If the fan motor shaft is threaded there should be a nut holding the blade on. Also yur motor bearings could be going bad causing vibration which damages the fan blade.
Sep 22, 2009 | Electrolux Freezer Kelvinator Single Door...
Refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Feb 27, 2009 | Amana ABB1927DE Bottom Freezer...
FREEZER SOUNDS VERY NOISY
that because the internal fan is hiting the ice or has bad bushings you can hear the noise just with the door close because when you open the door there is a switch the one turns off the internal fan so when you close the door it turn on the fan again if you wants to hear that with the door open just open the door and push the botton swich with your fingers and you'll hear the noise
Dec 29, 2007 | Freezers
Kenmore/Whirlpool GX5FHDXTS
I'll bet the freezer is not as cold as it was. Fully defrost the unit by leaving it unplugged for about 2 days. Check all gaskets. Clean the condenser coils under the unit. Restart. You have too much condensate in the box...either uncovered food or windowshopping or somebody didn't shut the door properly.
Dec 22, 2007 | Whirlpool GX5FHDXTS Stainless Steel
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
