Question about Sharp XR-10X Multimedia Projector
Flasing red light
Last night my xr-10x-l worked fine Shut down fine as I remember? . To day all I have IS A flashing red light. I pulled the bulb it looks ok checking it with a meter it shows open?
Does this mean the bulb is bad?
Power light green the lamp light flashes green for awhile then goes red. Replaced the bulb same problem.
I unplugged it then held the power button on and plugged the power cord back in. it started working correctly, and shuts off and on ok now.
Posted on Jul 17, 2008
  • 4,234 Answers
The flashing red indicates that either the fileter cover or the lamp cover is not installed correctly. If both are installed properly and secured, the unit will require service.
Dan
Posted on May 09, 2008
I have a Sharp XR-10X-XL projector, i have replaced the bulb but it still will not go on. The Stand by light and the bulb light are both on constant red, I have checked both the heat sensor and the fuse on...
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Dec 13, 2010 | Sharp (AN-XR10LP) Projector Lamp for XR10X
My xr 10x lost power last night, stopped dead. No
make sure the lamp door is engaging the safety switch. if it is then the a/c input board is bad or the power supply.
May 15, 2010 | Office Equipment & Supplies
New bulb in now wont work - no power - wont turn on to reset lamp
first, make sure you have the correct lamp. the lamp for the xr-10x-l looks like the xr-10x, but the plugs are different (common mistake). make sure you have the AN-XR10L2/1, not the AN-XR10LP/1. to reset the lamp timer (with the projector plugged in but off), hold down the enter, down arrow, and menu buttons and press the power.
May 30, 2009 | Sharp XR-10X Multimedia Projector
Sharp XR-10X projector, but missing the projector bulb.
if you plug it in and turn it on, you should at least hear fans running, then it'll shut down because there is no lamp. that's about it.
Apr 01, 2009 | Sharp XR-10X Multimedia Projector
Sharp XR-10X Bulb works once then nothing
this is something which sharp didnt foresee!!!!!!!!!!
sharp has two identical models
sharp xr10x & the newer model xr10xl.both the lamps look alike , however both have a different rating & reverse connector!!
i.e both cannot be interchanged!however if u have the old xr10x & if u try to fit the new bulb which is lower in wattage, it will explode in 20 mins
if you have bought a used projector , then u wont know if someone has interchanged the ballast!!
as this model was discontinued 2 years back!!!!
so confirm the model , it is mentioned under sharp name or at the bottom
good luck
Feb 05, 2009 | Sharp XR-10X Multimedia Projector
Sharp XR 10X lamp replacement issues
I sent mine in. They changed the bulb and cleaned the unit. The one thing they did suggest that seemed helpful was to upgrade the firmware. They did this as part of the service. That may be your problem, but I don't know that the firmware is upgradable. Yes indeed, they do charge an outrageous price!! I went through Sharp because they would guarantee the work, and I didn't want to buy two bulbs.
Oct 01, 2008 | Sharp XR-10X Multimedia Projector
Flashing green light
1. Pls check and inspect the Lamp unit.
2. If Lamp unit is okay, Then the Problem is with
either with Ballast unit or the DMD Module.
Regards
Viren
May 31, 2008 | Sharp XR-10X Multimedia Projector
Flashing leds no picture
when You changed the bulb  you have to reset the bulb timer , that why the light is flashing red , look at your manual and reset the timer , and the picture , changed bulbs myself before i found what the problem was ,
Mar 25, 2008 | Sharp XR-10X Multimedia Projector
Sharp XR-10X Multimedia Projector Logo
1,119 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
