Question about Qca Spas Paradise Series Paradise Ultra Xlp Hot Tub
Our hot tub ran last night for 2 hours then threw the 60 amp breaker. We checked and all looked ok. we turned it back on and it ran for fove minutes and it threw the breaker again. It just keeps doing it again and again. any suggestions
  • 8,404 Answers
I think you have a leak that is dripping onto your control panel ... Your 60 amp breaker should be a GFI which is very sensitive. check it out ...
Posted on Sep 01, 2010
My hydroquip cs6230-u pack on my hot tub shuts off for days and comes back on. None of the circuit breakers pop. The cold weather is coming and I don't want any pipes to freeze. I would also like to u
I do not know this unit so this is only a guess on my part.
I am not sure what you are by it shuts off for days. If it is hot that may also cause it to shut down but for less then an hour. The manual can be found by googling:
hydroquip cs6230-u pack manual
Several of the manuals show up. Be sure CGFI is OK.
This is what I found in the manual. Measure your water temperature it may be OK.
FREEZE PROTECTION - There are two(2) levels of freeze
protection integrated into the system.
1 - SMART WINTER MODE, this mode will activate any time the
temperature falls below 59BF. This mode will be active for a period
of 24-hours. In this mode, if a pump has not been activated in the
last 2 hours, the system will automatically turn it on for 1-minute
to prevent freezing. The "Filter Cycle" indicator will illuminate
while this mode is active.
2 - If the spa water temperature drops below 49BF, the heater &
pump will be activated until the water temperature reaches 50BF.
While freeze protection is active no other functions will be
possible.
Nov 28, 2014 | Cars & Trucks
My hot tub has been running perfectly until a few nights ago when the GFCI breaker tripped and now it wont reset
Either you have a ground fault or the GFCI is toasted. Turn off the power to the GFCI, open the box the GFCI is in and disconnect the output wires, close up the box, re-energize, and try to reset it again. This will tell you which problem you have.
Jun 04, 2012 | Cutler Hammer CH250 2 pole 50 amp
Why is my 50 amp GFIC breaker tripping out? I have just installed a new hot tube.I had one there before(smaller 40 amp) so there was already #8 wire there.The new hot tub requires a 50 amp. #6 wire. I just...
There might be a few things here:
1) Big problem >> the #8 wire is a fire hazard connected to a 50Amp breaker
#8 is a 40 amp breaker
#6 is a 55 amp breaker
We put #6 on a 60 amp breaker
Are you saying you hooked the #8 wire to the new 50 amp breaker, and the hot tub called for #6 wire?
Upsize your wire and breaker to meet code
http://waterheatertimer.org/pdf/Wire-size-amp-rating.pdf
2) After putting the correct wire and breaker, you can still have a short in the circuit somewhere
We used to set equipment out in the field in early morning >> the grass was wet >> our equipment was fine, but the tiniest short would cause the GFCI to trip
I don't know where the problem is without a thorough checkout of every possible grounded surface. You need a good multi-meter
3) You better get an electrician over there to have a look before the place burns down or somebody wakes up dead in the hot water.
If I sound a bit scary here, it's because something doesn't sound right with your installation.
Oct 19, 2010 | Inline 60 Amp Circuit Breaker
My tub trips out upon power up was working ok last nite 28/4/2010.
I don't know how you have it wired, but it is possible that the heater is on at the same time the pump starts and trips. The starter windings in the motor need all of 15 or more amps to start, that is why the lights dim when the fridge starts up. Anyway, if the heater is on the same line, same breaker, it needs to be bigger, and in 110 volt mode , you can't go any bigger than 20, but in 220 volt mode, you can go to 60 amp. that would be 30 amps each, potentially. depending on the voltage of each. Last time it worked ok because it wasn't crossing the line with a start up motor and water heater working at the same time. Now that you are totally confused. Check the breaker, see if there are 2. one for the heater, one for the motor. Hope this helps.
Apr 29, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
240 w/60 a outside breaker with test switch wont'
Inside the controller box is a red button to reset it but most likely the heater element is shorted out so replace the heater element first. Cost $100.00 at any pool or spa shop. Post here if you need more help.
Sep 28, 2009 | Siemens 12 Q115u 15a Circuit Breaker, Qp
My water pipes froze thursday night so friday night when i went to bed i left the tubs hot water turned on and they thawed out about 2am i got up and turned the tub faucets off the water was hot at that...
you probibly ran the hot water tank out of hot water shut off the hot water comming out of your fausets for a few hours and check it again u could also try to reset your tank by pulling off the front cover and hitting the reset button and my last thought is sadly you burnt out your heating elements and they need to be replaced good luck man
Feb 28, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
30 amp 2 pole GE GFCI breaker pops on hot tub after hrs of use
I have seen circuit breakers trip at a lower amperage. It seems that they are weak. Generally circuit breakers run with 80% load with no problem, in your case 24 amps. I would replace the circuit breaker.
Jan 11, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
115 volt 20 amp breaker for hot tub keeps tripping
Is there anything else on the same breaker? Is that the proper amperage for the pump? How long has the pump been in service? It may need to be cleaned as possible obstruction causing too much strain.
Nov 29, 2008 | Waterway 1.5 Hp 115 Volt 2 Speed Side...
Qca Spas Paradise Series Paradise Ultra Xlp Hot Tub Logo
222 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
