Question about Matrix T3Xi Treadmill
Error code 4 matrix treadmill - Matrix T3Xi Treadmill
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: My Matrix T3X treadmill display doesn't work
tight the ribbon cable keypad, clean it +tight the wires connector from display board vs lower board and clean it.
2) adjust the reed switch, clean it and tight the wires connector.
see the diagram.
God bless you
Posted on Jul 20, 2012
ercupa190
  • 12223 Answers
SOURCE: matrix MX-3 error code 1
see the diagram attached for the speed sensor. test for open or faulty. clean it, and tight for plug or connector.
2) Test the input voltage motor, if there are the motor need repair
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Posted on Dec 17, 2012
T5 treadmill error 4
https://www.google.co.uk/url?sa=t&source=web&rct=j&url=http://www.gympart.com/TSB/Matrix%2520Fitness/Treadmills/T5_G1_TM65/D/T5x_G1%2520Error%2520codes.pdf&ved=0ahUKEwjBvZbqzJLTAhWdF8AKHTIOCf0QFgghMAA&usg=AFQjCNG-fvYDtHHAA9AhxI3uFbtQXKB8mA
Apr 07, 2017 | Exercise & Fitness
Error message 02A0 stays up on the and the treadmill will not start
hi,
Here i have added the list of error codes list for t5x .
Check the same and confirm which error its shows. error 02A0 is not listed any where.
ERROR
Aug 20, 2013 | Matrix Commercial Treadmill: Mx-t5x
Matrix MX-3 error code 1
God bless you
Dec 16, 2012 | Matrix T3Xi Treadmill
Life of running belt in matrix treadmill
all depende how frequently you LUBE the deck belt, may you have a worn Deck. see the instr. manual and see the video.
God bless you
Aug 05, 2012 | Matrix MXT5 Treadmill
My matrix MX-T5x start running and stop in seconds. With the error code E7. What is the problem ?
By E7 it means Speed sensor feedback missing. You have to check the speed sensor mounted near the motor pully. Remove the speed sensor and clean it well Then refix it then check the tread mill by powering ON. If then also the problem remains the same , You have to replace the speed sensor.
ok
Aug 02, 2011 | Matrix MXT5 Treadmill
Hi, i have an Error signal " 2 - 9 F " the treadmill stops and cant run anymore. thanks a lot!
I have a Matrix Treadmill t4. An error of "E1 and E3" occurs when it is started? Can you tell me the solution?
Mar 15, 2011 | Matrix T3Xi Treadmill
ERROR CODE E 7
Have you tried to recalibrate the unit? Walking belt sticky at all? Smell anything? Does this use a red dc motor? If so, check for a burnt "choke" (looks like a small transformer near the controller bd). Elevation function at all? Can you get the walking belt to start?
Oct 19, 2010 | Matrix T3Xi Treadmill
Matrix T3Xi Treadmill Logo
151 people viewed this question
Top Matrix Exercise & Fitness Experts
David Payne
David Payne
Sportsmith LLC
Sportsmith LLC
greg kinsley
Are you a Matrix Exercise and Fitnes Expert? Answer questions, earn points and help others
