The air conditioner is humming but the fan is not turning. What would cause this problem and can it be fixed?
  • 674 Answers
The most common thing is a bad capacitor for the fan motor. You can test it with a multimeter with the capacitor test function or take it to a heating and air supply and they can check it. If the capacitor looks swollen then it is bad. The capacitor can be made of metal or plastic and will look like a small can with some terminals on one end. Another thing would be a bad fan motor. You could use and ohmmeter to check the fan windings.
Posted on Sep 01, 2010
My rooftop air conditioner is making a humming noise, but will not blow out air. The fan will not kick on manually from the thermostat. The humming stops when I turn the thermostat to off.
check the capacitor of the fan motor may be it was bust u can see physical by the size bulge if u found damage. change it to new one with same rating then it will fix your humming problem.
Aug 20, 2016 | Heating & Cooling
Air unit fan not turning and its blowing hot air . the motor is running and making a humming nosie.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 13, 2011 | Heating & Cooling
Carrier 38CKC036350 condensor fan not spinning makes humming noise compressor hot fan can be turned by hand
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 27, 2010 | Carrier 38CKC036 Air Conditioner
Maytag air conditioner turns on but fan does not blow. When I put the unit to fan only, I hear the hum of the fan, but no air coming out.
Either the capcitor has gone bad for the fan motor or the motor has siezed up or gone bad... you cold try to replace the cap. first and move on from there....
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 17, 2010 | Maytag M7D24E7A Air Conditioner
The fan on my outdoor compresser unit has stopped working the motor is humming and the fan doesn't turn if you manually push the fan blades around the fan will spin but at a very slow speed. The unit was...
It could be either one or both...usually I like to do both at once because either one can cause the other to fail...that problem is a common one for air conditioning units...
heatman101
Jul 23, 2010 | Bryant 463AAC008BA Air Conditioner
Duo-therm mod # 57915 not cooling fan?????
need to get at the capacitor for the fan. Try spinning blower when it hums. If it runs then the cap is bad if not the motor.
Aug 13, 2009 | Dometic Rooftop RV Air Conditioner
My outside condenser fan motor hums and slowly turns even though the thermostat is turned to off position. the furnace heats and cools like it should.
hi there,
check the capacitor of your condenser fan,if busted replace,although thats the common causes of hummimg motor,it can't start,consider also after replacing capacitor still hum,check the motor start winding,and the supply from the source of relay in control panel.have a nice day
May 08, 2009 | Frigidaire FAS155K1 Air Conditioner
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Kenmore Window unit 15,100 btu, Model 25372156200
with the hum noise sounds like you have a bad fan motor
May 26, 2008 | Maytag M7Y15F2A Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
