Question about Kenmore 67032 Dryer
Takes a long time for the clothes to dry, the clothes seem to be hot but I do smell an occasional electrial short. My vent is clear as far as I can tell and the lint catcher doesnt seem to be collecting very much
  • Kenmore Master
  • 3,740 Answers
Hi and welcome to FixYa I am Kelly. Go outside and check the thru the wall duct for obstructions. Both sides of the external flapper for lint. Then do the same thing for every inch of the vent ducting inside and outside of the dryer. Your looking for lint build up. Pull out the lint filter... use a flash light and look deep in to the lint filter cavity. Use a vacuum crevice tool and a folded coat U-shaped wire hanger to clean out everything UNDER the lint filter. Wash the lint filter with vinegar and water then soap and water to remove dryer sheet (bounce etc) particulate that over time blocks lint filters.
Then with the vent duct removed from the rear of the dryer inspect into the hole for lint... clean as necessary. After all of the above with the vent still disconnected heat on or off check to see if the airflow out the back of the dryer is strong enough to gently push a relaxed hand and wrist away from the dryer vent exit of the dryer. If it does NOT do this them most likely the blower wheen hub has failed and the blower wheel is not driving at full speed. The only option if this condition exists is blower wheel replacement.
That electrical smell you notice is the excess heat inside the dryer usually either in the heating element or gas flame duct getting hot enough to burn internal lint and cycle the high limit thermostat. Once you clean vigorously and correct any blower wheel problems your dryer this condition should cease making the smell.
Thanks for choosing FixYa.
Kelly
Posted on Sep 01, 2010
  • 417 Answers
take the hose off and run it without the hose hooked up. feel how much air is coming out of the hose, it should be flying out. feel the body of the dryer mid cycle, it should be just lukewarm, you should be able to keep your hand on the top of the dryer without having to remove it. It sounds like its half clogged on the inside. its going to have to come apart. your dryer is a newer model and I havent taken many of those apart but I imagine you start behind the control panel, remove the screws behind that then flip the panel forwards and theres more screws there, remove the access panel behind it at the rear. look inside there with a flashlight (unplugged of course) and your looking for the idler pulley, it has a strap and it has to be bent up or down to release the belt, might have to study it. now with the belt loose, go around to the front and look for more screws inside the door to remove the top.possibly more screws near the bottom corners of the front, use different saucers to put the screws in once you get the top off the drum of the machine should lift out, if not there may be screws to release the drum in the back of the middle of the drum. a couple more screws releases the front. draw a diagram of the wire harnesses you have to undo and their colors and where they go. now look all over for lint, especially right around the fan ductwork. go to this website for manuals and pictures of disassembly and soforth.
www.appliancejunk.com
good luck
jm
  • Kenmore Master
  • 8,404 Answers
I believe your vent is clogged ... clean it end to end ... if it is plastic, replace it with a aluminum ...
It is taking far too long to dry, this has only recently started? what could be the problem?
Does it get hot? If it does, then the problem is reduced air flow, caused by a lint filter that hasn't been cleaned, masses of fluff in the exhaust pipe (usually on bends), or the external vent not opening properly. Birds can also nest in the vent pipe if the vent isn't protected or is broken.
If it doesn't get hot, you need a new element. Some dryers have two elements if the dryer has a high and low setting. just one element can fail.
Jan 20, 2016 | Zanussi TC7102W Electric Dryer
Maytag Centennial Dryer (MEDC400VW) not drying properly
First of all, please make sure the vent is clear all the way through. Next the vent must be straight as possible. Next it can not be to long. People think that because they feel the air outside the vent is clear, not always true. The vent can be partially clogged. So make sure. Next, if the vent hose has sags or bows and even tight turns. It can accumulate the moisture in it from the drying proceed. If water has collected in the vent hose the clothes will not dry properly. If the vent is to long it can not dry properly either, the blower on the dryer can only move air so far. So the shorter the better. If all of these requirements are meet. Then, I would have to start checking the thermostats. I hope I have helped you. Please respond if you need further assistance.
Jan 29, 2014 | Maytag Dryers
Takes long time to dry
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 16, 2012 | Kenmore Dryers
Dryer takes too long to dry. GETS HOT...but not drying. Ran two cycles, frame work was hot, but clothes were not compelety dry. Note: not any lint either.??
make sure all the venting is clear of build up and debris,, clogged venting will not allow the moisture to escape the dryer resulting in damp and undry clothes ,, don't forget to check the outdorr vent and clear anything built up inside of that too
Jul 12, 2011 | Dryers
My kenmore Electri Dryer is humming while drying.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.hope this help you out sincerely D.Jones
Jun 08, 2010 | Kenmore 64672 Electric Dryer
Whirlpool dryer model #GEW9250PT1 not drying properly
when was the last time you cleaned your dryer?all a dryer does is move air around and if it can't cycle through the dryer the clothes won't dry. unplug the dryer and then you need to clean the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line,if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean it out,make sure the outside vent is clear first then blow it out,if it's a short run vac it out,most problems start just from lint buildup,the clothes don't dry the dryer runs hot and parts start messin up,also vac out under your fridge,take the bottom kick plate off and vac it out,you can kill the compreesor if you don't,good luck
Apr 05, 2010 | Whirlpool Dryers
My Maytag Quite Plus clothes dryer gets warm but not as hot as it use to. It seems to take a very long time to dry clothes. Vent is clear. The moisture gage seems to flicker lately.
most dryers have two heating elemts and when one goes out this increases the drying time and could cause a elec. short and trip a braker can be replaced.. There is also a saftey switch that goes bad and will not let the heating elemt work properly ?
Mar 25, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore dryer. Heats up intensely
Hi, It's an over heating motor that's cousing the thermal switch to trip, on the motor.
Motor retails for $150.
Labor for putting it in is $90.
It might just be worth replacing it.
Sorry for the bad news :(
Best of luck.
Sep 13, 2009 | Kenmore 64902 Electric Dryer
Water on floor in front of dryer taking a long time to dry
look inside the washer dryer for another hose -- it is clear and assists with draining
Feb 24, 2009 | Dryers
Dryer warm but not hot, long dry times
some times there are multiple heating elements in there and if one is out it does not get as hot. another simpler place to start would be to make sure your line is clear of debries all the way from dryer to out doors. this is a good idea any way since lint build up can cause the occasional house fire.
Jan 23, 2009 | Dryers
Kenmore 67032 Dryer Logo
112 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
