Question about Sharper Image Vacuums
A couple of months old. this steamer no longer heats. The switch lights up, there is power, but no heat
  • Sharper Image Master
  • 17,129 Answers
Must have to check the resistance of the coil, if open resistance, the coil is damaged. I think you are in warranty period and must check with the dealer for a replacement.
Before you open the set call up as sometimes the warranty lapses if the seal is broken.
Posted on Sep 01, 2010
Low power from steam mop
Try to be a little more vague! Model? Age of steamer? Rate of use?...Try a couple of drops of vinegar in with the water you use to fill your steam mop. The heating element that heats the water is probably oxidized, especially if you use tap water to fill it. You should only use distilled water in these mops. Some lower end steam mops have a handle that compresses, as you push the mop forward, which essentially makes the mop steam more, the more you "pump" the handle. Hope this helps!
Jan 29, 2015 | Vacuums
My compact steamer does not let the steam out when I press the black release button help?
I examined mine. There is literally NO hole in the steam wand for the steam to exit. It's a wonder the thing didn't blow up. Take it back and be glad you still have your face.
Jan 01, 2015 | Top Vacuums
Steamer problems
The light is connected to the heater if it is not working but the unit still gets hot the light may be faulty
If the unit does not get hot then there is a problem with the power getting to the heater element.
The fault may be in the switch
Aug 08, 2014 | Eureka 313A Stick Steam Cleaner
It wont get hot
The manual for your EP961 says that it needs at least 10 minutes to heat up before it will produce heat. A yellow light will light up when it is ready. Did you wait the appropriate time? Also, there are 2 switches, one to start the system and another on the handle to start steaming once the water heats up.
Is this a new steamer?
If you have used it before,are familiar with it, followed the directions and still no steam, then I would contact the company for repair.
Hope this helps,
Handie Andie
Mar 25, 2011 | Euro-Pro EP961 Steam Vacuum
My unit was working perfectly, then all of a sudden the heating unit quit. It's only two months old. What happened?
It's still covered by warranty, so I suggest taking it to where you got it. If they don't have a warranty station, you can find the nearest one on the below site.
http://www.eureka.com/Customer-Service/Store-Locator
Oct 05, 2010 | Eureka Deluxe Enviro Steamer Vacuum
Shark floor steamer: Does not produce any steam and no lights are on.
Hi All
Shark steamer that the light is not on and will not heat up. I have found that there is a in line slow blow fuse in side. replace this fuse IF you can find one and the steamer will work. If you let the unit run dry and leave the unit on it will get hot and blow the fuse!
I am looking for the fuse myself. good luck! Dan FL.
Dec 17, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have an electrolux Enviro multi steamer which I was using this morning. I turned the steamer off for approximately 1 1/2 to do some shopping, and when I turned it on again, the steamer light turned on...
Problem fixed itself. Turned off for couple of hours so unit can cool down completely and when I turned it back on it started working again.
Dec 14, 2008 | Vacuums
Vacuums Logo
150 people viewed this question
Top Sharper Image Vacuums Experts
JoeVacs
Are you a Sharper Image Vacuum Expert? Answer questions, earn points and help others
