I am using ELBA washing machine EWF 656 and ELBA dryer (mounted on top of washing machine)for past 3 years. Recently, I was shocked to find out that the whole dryer almost tumble down and the washing machine itself moves out of it position in the process of washing. What is the problem? Pls advise.
2 Suggested Answers
  • 6277 Answers
SOURCE: my elba washing machine model
Filter first, Manual second ;-0)
(if your particular model has a filter)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter- so many 'faults' are caused by blocked filters.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If these have assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 25, 2011
My Elba washing machine, when reaches the rinse cycle, water is very loud, never before, but it never stops adding water. Water is draining fine but water does not stop to cycle to rinse.
The water inlet solenoid valve is being held open. Take off the hose and look in the opening to see if you can find anything. Otherwise replace that solenoid valve.
Sep 02, 2016 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
Elba washing machine wont drain or spin
The pump filter is blocked ,so it wont empty,remove filter cap and clear out lint, coins etc.
Jan 03, 2014 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
I have a haier washer-dryer combo. washes and dries but it is making a loud clanking noise, esp loud during the spin cycle. draining well.
Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
Feb 12, 2013 | Haier Washing Machines
Electrolux front washer EWF 1087 bangs loudly at the start of spin cycle
It is so common that the washing machine can make terrible noise in many ways and is a common fault.Check the suspension, shock absorbers and spring mountings, check the levelling of the machine.If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 24, 2013 | Washing Machines
My stackable top loading washer tub is tilted over. It was listing before and now it is several inches off center. Is this a problem that can be fixed or will it have to be replaced?
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Stackable washer and dryer. The washing machine tub is tilted to one side.
Jun 30, 2009 | Kenmore Washing Machines
Kenmore stacked washer and dryer was washer spins but out of balance
Apr 21, 2009 | Kenmore 94802 Front Load Stacked Washer /...
My Kenmore 70 series top loading washing machine is 12 years old and has been working fine. The last time I took clothes out of the drum I noticed that it is extremely wobbly. I can almost push it so far...
Feb 23, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
731 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
