Xerox color DC 3535 ESS HDD replace.
How can use new local market note book HDD in DC 3535
    President:
  • 2,072 Answers
You would have to have the proper ESS software to load on it.
Other than that, I don't believe much else would be required.
Posted on May 13, 2008
My dc 3535 machine problem ess pws softwer
  • hy hru ?
  • my 3535 machine problem for a i you give pws diagnostic tool version 3.10
Apr 21, 2012 | Xerox DocuColor 3535 Copier
How to replace the drum of dc 3535
remove drum cartridge outside
remove 2 black cap of drum cartridge
then take a small steel rod enough lenght of that drum and put in that hole appear one side of drum
and press it so that other side nob comes outside
again from second side remove the nob of another side
remove all bearings gear
place a new drum and fit all bearing and gear
reverse procedure from downside to up
Jul 23, 2011 | Xerox DocuColor 3535 Copier
DC 3535 010-350
That is an over heat error.
Please call for assistance from authorized Xerox Service.
Mar 24, 2011 | Xerox DocuColor 3535 Copier
I have a Xerox dc 3535 that I need to set the admin password on (don't even know what it was) how do i do that?
The default password is "11111", via Workstation CWS the admin password is just blank.
Oct 08, 2010 | Xerox DocuColor 3535 Copier
Dc 3535 004-361
you have a problem with color drums motor, try to rotate in a colckwise manualy each color drums, if someone is hard to turn (comapred with a new one) replace it and problem will gone.
good luck
Aug 23, 2010 | Xerox DocuColor 3535 Copier
In xerox dc 3535 i feal new toner cartrege but the consumabel say toner expty what i do
open the front panel and top panel
find the palce from where toner goes down side
there is two small wheels one is vertically positioned and another is horizontally
there is problem i suggest
Jul 01, 2010 | Xerox DocuColor 3535 Copier
I have an error DC 3535, the code 116-201
it is error of Hard disk booting
Run the HD Diag
or install it from opertor
Jun 09, 2010 | Xerox DocuColor 3535 Copier
Xerox DC 3535 error 116-332
Simultaneously press and hold the 1,the Stop
and the Power Save buttons on the Control
Panel,if problem continues repeat the same
with
6,the Stop and the Power Save buttons
4,the Stop and the Power Save buttons
3,the Stop and the Power Save buttons
Aug 28, 2009 | Xerox DocuColor 3535 Copier
Error 116-365 on dc 3535
That is a hard drive error.
There is a job stuck on it.
Hold 4 + stop + powersave as you turn on the machine.
That will cause the Hard drive to initialize and should clear the job.
I have seen that caused by someone doing an internet print job.
You may want to unplug the printer cable and see if an incoming job is corrupting the network. I have even seen networks be hacked and the machines affected.
If that doesn't reset it. Check the connections to the hard drive.
When you do the hard drive initialization. Hold the 4 , the stop, and power save as you power it on , hold the buttons until you see the progress bar appears on the screen, then release the keys.
Jul 06, 2009 | Xerox DocuColor 3535 Copier
439 people viewed this question
k24674
jasbo
jasbo
