Question about Maytag MDE9700AYM Electric Dryer
Dryer got really hot - would not start again. Ck breakers; OK - Unplugged dryer- re-plugged. would not start. Had power - all lights working. Repairman replaced a 'fuse' down in the front of dryer(and I had a service clean the vent pipe). Did 1 load, worked fine - did second load, left it for a while, so wanted to air fluff - unit would not turn on- same scenario. Was the part defective, or did the repairman not install it correctly?
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 04, 2010
Plugged in but no power from cord to machine
Ck your breaker box and make sure that the breaker for the dryer is not off if it's not ck at the back of the dryer to see if it's possible it has come unscrewed from the dryer itself first make sure it is unplugged if it's a old dryer look at the end of the plug to see if it is black if it is the plugin is bad
Nov 23, 2015 | Dryers
Dead. As if unplugged. Checked breakers et al.
1.Check dryer door switch.
2.Hold dryer door switch and listen.
3.Place a jumper wire between the switch prongs.
Mar 05, 2010 | Whirlpool LEB6200 Electric Dryer
My dryer won't turn on what can i do?
Check house fuses or circuit breaker.
Ck. power cord and power outlet for signs of arching an replace if needed.
Ck. power cord at dryer side and make sure the ends are not burnt. Unplugged of course.
If all is ok call for service.
Jan 16, 2010 | LG DLE2532W Electric Dryer
Dryer is runing but not getting hot. What could
First check is to reset the twin breakers for the dryer in the house electrical panel--push off, then on. If the dryer now heats, you are home free. If not, measure the voltage (should be ~230 volts AC) across the two slanted slots in the dryer power socket. If nothing, leave the dryer unplugged and reset the breakers again. Try measuring the voltage again--if still nothing, you have a failed breaker (one is still good) or a broken/loose wire between the breaker and the power socket (contact an electrician to check that out and repair). If you measure the required voltage, then you have a problem within the dryer--usually the heating element is open or the thermostat or high temp safety thermostat is bad. Usually, the drum must be removed to repair the heater. Good luck!
Dec 26, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Dryer will not start
if elect dryer ck the breaker box . turn power of and back on . if power ok open door and see if sw clicks if it does it's probably ok . reset any buttons and try again . if it mks any noise it may be motor . like a growling . or just huming .. / hope this helps . mm
Dec 23, 2009 | Dryers
Dryer will not turn on
if dryer is elect ck the power first /it may have blowen the breaker . one side . this happens a lot . turn both lines off and then back on . . if ok go back to controls and ck w ohm meter . "Q" why were you removing panel . did you have another problem ?
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Sep 12, 2009 | Maytag Dryers
Dryer trips breaker as soon as i try to start it.
Use or borrow a volt ohm meter and check for a grounded hot wire. You may also be exceeding the start up load on the 20 amp breaker. Test this theory (after you make sure that there are no ground faults) by starting the dryer in a "air fluff" mode without heat. If the dryer starts in the "no heat mode", switch the heat on - if you blow the breaker you know that the 20 amp breaker cannot handle it. Before you do any of the above - check your dryer manual for the service requirments. If you don't have the manual go to the mfg. web site and download it.
Feb 04, 2009 | GE DBXR463GB Gas Dryer
Kenmore dryer
first dryer should be on circuit by itself..if dryers runs ok for a while before tripping breaker call electrican to change breaker..change it not ck it ..too many times had electricans tell cust breaker ckd ok but after explaining to cust a breaker can not be ck without load they had breaker changed and solved problem ..not just old breaker but even new ones can cause problems..if breaker kicks as soon as dryer is turned on ck wiring at connection where ac is connected very seldom does any other issues with dryer cause immediate tripping of breaker
Sep 16, 2008 | Kenmore 63012 Electric Dryer
Whirlpool Duet Dryer
Friend,
huuum At your service!
You said:
Everything was working fine, now we get no panel lights, the dryer light doesn't, dead in the water! Checked the plug...unplugged it and plugged it back in. Checked the circuit breaker...ok. What next?
I'm sorry to tell you that you need hands on service.
If I were there hands on I could diagnose the problem.
You may have an electronic malfunction and that only a trained technician can diagnose!
SORRY!
Bless You,
huuum
Please give me a good rating before you sign off
thank You
You will be fine
Bless You ,
huuum
Please give me the best rating for this solved solution!
Thank You!
Sep 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag MDE9700AYM Electric Dryer Logo
74 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
