Question about Aiwa NSX-A777 Shelf System
3-cd drawer opened (aiwa cx na 777) and my brand new Iron Maiden CD dropped inside of the unit below the disc spin device (motor shaft and hub?), now I'm afraid to close the drawer. I want to take it apart to retrieve my CD. Any parts diagrams or exploded views?
    Top Expert:
  • Aiwa Master
  • 74,383 Answers
Hello
You have to open the unit to take the CD out of it. If you can, do this. If you are not able to doe this work, contact the nearest authorsed service center for Aiwa at your town. Aiwa is not a brand in market now, as Sony Corporation has purchased Aiwa. so it will be best to contact the Sony Authorised Service center at your town. OK.
Posted on Jan 19, 2012
2 Suggested Answers
  • 120 Answers
SOURCE: I need a manual for
what is the problem with your aiwa, i have worked on several of them in the past.
Posted on Jan 15, 2009
The AIWA CX-ZR525 wont play cd's, it will only pick them up and leave them there with no music
Presuming that other sources work okay and the the cables are connected correctly.....Try a CD Lens cleaner.
If that doesn't work then it's time to open up the unit and manually clean the laser lens. If that still doesn't work then the laser might be dead. Replacement parts may be available. Whether or not you can do this as a DIY repair though is questionable. It depends on your skill.
Sep 14, 2014 | Audio Players & Recorders
The tray of cds does not work properly, does not allow the change of disc to disc and stuck
Try pressing repeatedly the eject button while you turn on the unit. If this doesnot work
then it is a mechanically problem in your player .
You need to manually open to take out the cd .
The rubber thread which should be connected to the motor inside the cd player might have moved from its place.
You need to place the rubber thread to proper place.
Also if the belt is slipping, the mech never gets the "drawer closed" signal, and the disk will not spin.
Mar 04, 2009 | Aiwa NSX-A505 CD Shelf System
Player doesn't recognize most CDs - 'no disc' message appears.
Your player lens needs to be cleaned by a lens cleaner...
Feb 24, 2009 | Teac CD-P1260 CD Player
I need a manual for an AIWA CD/Radion Model CX-NA 777.
Jan 14, 2009 | Audio Players & Recorders
Aiwa cd3 model #cx-na 22u will not acknowledge cds spins then stops
Optical lens might have dust on it so...Try to clean optical lens with cleaner CD then check.
If problem still exist then clean lens with cotton bud by taking off top cover of unit. Make sure to unplug unit from AC outlet before opening top cover.
Jan 09, 2009 | Audio Players & Recorders
Aiwa Stereo
Same model, same problem. (CX NA-50) I have one that worked great for two years (at best) and I haven't used it since then. I recently decided to look for a solution via the internet.
I read somewhere else that there was a class action settlement with aiwa (now expired) since many of these units had this problem.
Oct 25, 2008 | Aiwa NSX-DS55 CD Shelf System
Turning off auto on at fixed time
check and replace the switch of your shelf system may be it malfunctioning
Feb 19, 2008 | Aiwa NSX-A115 Shelf System
NAD C521 discs not spinning
The CD player has a sensor that is supposed to detect when a disc is inserted and spin it up etc. yours might be the problem, either it has some loose connections (that you haven't noticed) or it simply misbehaves. Another thing could be the motor itself that somehow 'misses' the spin up signal and needs a 'manual' boost. The best solution in your case is probably to bring it to some lab.
Sep 14, 2005 | NAD C521 CD Player
Aiwa NSX-A777 Shelf System Logo
540 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
