Question about Hitachi 43UWX10B 43" Rear Projection Television
Power light indicator blinks. Will not turn on.
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
I will attach some photos for you to look at.
The most common problem this set has is convergence failure which usually means resistors are burnt.
All you have to do is unplug set and look inside (from back) to the right---check out the resistors--are any burnt or discolored in the middle?
If this helps rate this solution as very helpful as I do this here for free.
SD TECH
Power light indicator blinks. Will - da294cd.jpg>da294cd.jpglOOK for any burnt or discolored in the middle, the colored bands denote the value of the resistor.
Posted on Sep 01, 2010
When i turn on my tv the little red light blinks. THen the sound comes on but no picture. After a couple of seconds the red light starts blinking again and the standby light comes on and then nothing.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 16, 2011 | Sony KP-51HW40 51" Rear Projection...
My sony bravia kdf-50e300 tv will not turn on. the green power light blinks then goes to a red blinking light 5 times. I tried unplugging it numerous times. Some forums suggestn it is the power board....
Jul 05, 2011 | Sony KDF-50E3000 Television
My standby light is red and blinking 6 times then quits, then blinks 6 times again then quits every time i try to turn on my tv
Apr 06, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
Same problem listed here: standby light blinking, won't turn on, bought new 7 yrs ago. Sony KV-30XBR910
Apr 06, 2011 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
Sony 3 lcd rear projection tv hd w/ wega gate. kdf-e42a10. tv will atempt to turn, shuts down, greem power light blinks 12 times on average. red standby light blinks 4 times. i replaced lamp [ xl 2400...
Mar 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
My standby light blinks 4 times repeatly and won't turn on
Jan 22, 2011 | Sony FD Trinitron WEGA KV-32FS320 32" TV
No power only plug light and battery light is on
The lights are indicators of which operation does your laptop operates.
1. Power indicator is lighten to green meaning you are in the mode of charging your power.and if the power indicator turns to orange meaning you are now using battery power or the charging is finished.
2. Reading indicator is blinking meaning your laptop is currently processing but if the Reading indicator is not blinking and made a static light then your system is in hang up or not reading the processes.
3. Wireless indicator is blinking or lighten then you are in the a wireless mode connection. Also the bluetooth and Infrared connectivity.
So please check which light indicator is lighten when you on your laptop.
Thanks
Aug 06, 2009 | Toshiba Satellite M115-S3094 Notebook
Blinking power indicator light
When TV indicator light is blinking and after that the power will cut off. First you need to check the power board. But I am still need more details of your tv. please call 323-767-6030 and I will go through thes trouble-shooting, with you.
Mar 08, 2009 | Astar LTV-32HBG 32 in. LCD Television
Power light blinking
I have a Toshiba 42H81 that has the power indicator light blinking and the TV will not turn on
Oct 14, 2008 | Toshiba 42H81 42" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
53 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
