Question about Sony Cyber-shot DSC-W50 Digital Camera
No image on screen
Hi. Hope anyone out there can help. My Cyber-shot DSC-W50 has a blank black screen. The lens extends when switched on, but no image can be seen. I am able to see the info on screen, like battery charge and different settings etc. But no image. I removed the memory card and replaced it but still no go. Any suggestions or solutions will be appreciated.
Richard
  • 3,037 Answers
The camera lens itself is either broken or the connected is severed. You can check this by opening the camera which might provide difficult for most people but is the only option to really see the exact problem unless you see the lens damaged.
Please let me know what you find, good luck
also, if you need any other help with this camera, please let me know, I would be glad to help
Posted on May 11, 2008
  • Benjamin Patri
    Benjamin Patri May 14, 2008
    Please don't forget to let me know your thoughts about my
    solution.
    If your problem is fixed, please rate this solution as that is one of the
    biggest aspects of how this website works and in order to receive any credit in helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to
    help.
    Thank you
    President:
  • 2,712 Answers
Tap side of camera with base of hand with 2 or 3 sharp taps. Then turn camera on. Problem should be solved. If not, then try the same with the camera ON.
You can even try a hard reset: Remove the batteries (and SD Card, if you wish), wait for a couple of minutes. Hold the power button down and reinsert batteries. Turn the device on.
If that still does not work, it could indicate a problem with the LCD mechanism of the viewscreen or the ribbon connector. In this case, you will probably need to get it serviced.
Posted on May 10, 2008
  • Swilin Sampson
    Swilin Sampson May 18, 2008
    Just checking to see if your issue is resolved. If it is, please assign
    a Fixya rating for the Expert whose advice guided you to a fix.
    Cheers!
  • Sony Master
  • 13,433 Answers
Hello joe
If everything is working but you don't see image on the screen while shooting for a image, then its a simple matter of changing a setting in the camera.
Is the camera working fine otherwise? Il get the details for you on how to change the settings in a moment.
  • Ekse May 10, 2008
    If the camera doesn't work and you can't take images with it then
    the camera needs service.
    you can get a free repair estimate from
    http://www.advancecamera.com/repair
    Let me know whats the status of your camera.
    Genius:
  • 3,422 Answers
The only solution to fix this is to get ti repaired.
or go to www.digitalcamrepair.com for help.
Goodluck..
Sony cycberzone dcs-w50 blur problem
Things can be faulted, One is called CCD imager, Flexible stip in the circuit and third one could be screen of the cyber shot. Contact with an expert repair man to diagnose.
Thanks
Sep 10, 2013 | Sony Cyber-shot DSC-W50 Digital Camera
Dropped camera and now the lens is stuck out,when i turn it on the screen says turn power on and off again.i do that,but it keeps saying it still and camera makes a weird noise when i turn it on,and lens...
Bummer huh? I dropped mine a while back and damaged my battery cover!
I would try...taking out the batteries and reinstalling them! This may reset your camera?
Otherwise, I would do a web search and type in:
Sony Cyber-shot Camera DSC-W50 troubleshooting
Hope this helps you get your camera working again!
Kind Regards!
Martie
Sep 15, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Lens will not extend, keep getting "turn the power off and on again" message.
Try grabbing the end of the lens while its coming out. That might free up and realign the lens. If you hear a grinding noise when the lens is moving, than your gears are chewed up. If it needs repairs go to esupport.sony.com Hope this helps
May 29, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Sony cyber-shot DSC-W50 digital camera when cutting on the on button on the camera it says turn the power off and on again.
You can try the following 2 ways: 1. Format and restore the initial value of the camera. 2.First open the battery box cover (notice: do not pull out the battery now), then start the camera, pull out the battery just after the Len has turn out. Install the battery a few seconds later. Now start your camera with the Play button which is next to the viewfinder boot, and then moving the hand wheel to switch to camera mode, after Image appearing the screen, the camera will work properly.
Dec 30, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Help! model DSC-W80
The problem with your camera is part of the lens but it not the shutter. It is the CCD it is on the back of the lens if you are inside turn off the flash and in a office light setting try taking a picture to see if you get any type of image. if you do than that confirms it is the ccd. the CCD is what convert the light to data to send the image to memory. if it is too bright and it is defective then you might eather get a white or black screen. Repairs for it can range 85.00 plus shipping and up. let me know if you need anything else hope this helps.
Mar 26, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Cyber-Shot Dsc-W70
Hi
You probably have a faulty lens unit. You can make sure of this by checking that the spaces between the two rings that extend forward at switch on has the same distance between each other.
If it is not the case, your lens is damaged and needs to be replaced.
It normally costs about 1/3 the price of the camera, so it should still be worth replacing.
Bear in mind though that only Sony Service Centres can help you as the y need to setup the new lens adjustments with Sony specific software.
Hope this helps.
Mar 09, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cybershot DSC-W50-not letting me take pictures
switch on when the lense extends take hold of the end and gently twist and pull the lense you may hear it click. be gentle do not force it then switch on and off again this should solve the problem
Feb 05, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Dropped camera and lens Dstuck , sony cyber shot DSC-W50
There are 3 pins in the camera lens that slide in grooves allowing it to move you have knocked out 1 or more.
only an experienced tech can attempt fix , camera must be totally disassembled.
Jan 29, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony-cyber-shot dsc-w50
Lens unit is faulty, may have had sand or damage at some time, focus assembly inside the lens is not focussing
Sep 16, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
