Question about Philips Magnavox DVD/VCR Dual Player
Trouble recording a vhs to dvd (non protected tape).
I am having trouble recording a vhs to dvd (non protected tape). Was working fine converting my library to dvd when suddenly it will not record to dvd anymore. The only "message" I get is in the display window of the unit, top right hand, it flashes "vcr --> dvd" 5 times and does nothing.
  • Anonymous May 11, 2008
    I NEED TO KNOW STEP BY STEP TO PUT A VCR MOVIES ON DVD
  • kimmyjay May 19, 2008
    can' finalize disk
Finalizeing a disk
Posted on May 19, 2008
Will this model record from the vhs tape to the dvd?
You don't state the manufacturer or model number in your question, thus we cannot answer. I will say that many do, but there is a caveat. If the the VHS tape is a commercially made movie, chances are it has copy protection on it. Most machines will sense this copy protection and will refuse to copy the protected VHS tape to DVD. This was done to prevent piracy. Home recorded tapes and non-protected tapes will usually work ok. Do not confuse write protection with copy protection however. Write protection is merely the tab on the tape that prevents re-recording of the tape. Copy protection is recorded right onto the tape itself and is read by the machine during playback.
Nov 19, 2015 | Televison & Video
Daewoo DVD-T "copy not possible - this media cannot be copied" when trying to copy from VHS (tape is not copy protected) to blank DVD-R and +R media. Same problem with all DVDs and VHS tapes
You can only copy non-commercial VHS tapes that you have recorded yourself to DVD. You can\'t make copies of most commercially made VHS movies due to copy-protection.
Dec 29, 2013 | Daewoo DV-6T955B DVD Player/VCR
For some reason I can no longer copy from my VHS tape to my DVD disk in my Toshiba DVR620KU DVD Video Recorder. I have tried some of the same tapes which had copied just fine in the past. I am using the...
How old is Toshiba DVR620KU recorder and how long it started this problem?
Does it playback previously recorded discs correctly?
Did you tried lens cleaning disc in recorder to clean optical lens?
These info will help me to suggest a solution.
Thanks.
Jul 22, 2011 | toshibadirect.com
I cannot copy commercially recorded VHS tapes to DVD. Msg comes up saying it is COPY PROTECTED. Heard that if for personal use only I am permitted to copy tapes. Any way around this?
No,this can be done only copyright materials through the VHS box converter run through a computer with a programs call copy decoders programs.Than u can copy VHS copy protected matrials.Than u reburn it back to DVD disc.So this require alot of work,time and money so not worth it to copy commercially VHS tapes to DVD Disc.
Jan 19, 2011 | Samsung DVD-VR320 DVD Recorder/VCR
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
I have a JVC DR MV7SU DVD/Video recorder. How do
If your camcorder allows you to connect to a tv or vcr and allows you to record from it to the camcorder via the rca video input, then you should be able to record it that.  The camcorder must have the RCA audio/video inputs on it to be successful.
enov8
Mar 08, 2009 | JVC Televison & Video
How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
Dec 30, 2008 | Samsung DVD-V4600 DVD Player/VCR
VR5940 DVD Recorder/VCR-Thinks a regular VHS tape is copyright protected
Don't know your machine, but is it possible that it's seeing your source tape as write protected (missing tab) and so assuming it should not be copied to the DVD?
Jun 14, 2017 | GoVideo VR5940 DVD Recorder/VCR
Dubbing vhs to dvd
Easy. Connect RCA lead from video/audio OUT on the VCR to video/audio IN on the DVD recorder. Set DVD recorder source to VIDEO then press play on the VCR and record on the DVD recorder.
Sep 09, 2007 | Aspire Digital AD-8091 DVD Recorder
Philips Magnavox DVD/VCR Dual Player Logo
125 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
