Question about Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor
How do you change the blade on a craftsman lawn tractor model 917.28726? I have the tractor on ramps, but can't seem to get the bolt off!
  • 2,926 Answers
Disconnect the spark plug wire from the engine to prevent accidental starting. Use a wrench or socket to remove the bolt, turn in a counter clock wise rotation for removal. You'll need to hold the blade still while attempting to remove the bolt. Use a breaker bar for more leverage if needed,sometimes these bolts are difficult.
Posted on Sep 01, 2010
How do you change cutting blade on a Sears Craftsman Mower?
Hi Bill:
Changing blades is pretty straightforward but does involve some Safety Hazards.
- Blades can have sharp bits - WEAR GLOVES
- Running engines can make the blade BITE - BAD
ALWAYS disconnect spark plug lead whaen changing blade.
Easy Part:
- Raise deck to maximum height
- If possible, park with front wheels on a ramp to get better access under deck.
- Use socket wrench to remove bolt from centre of blade. Here's where the gloves help as you hold the end of the blade to prevent it from turning when you apply force to remove the bolt.
TA DA! The blade will come off.
- To install new or sharpened blade (I use an angle grinder to sharpen mine) tuck it in place, install the bolt, snug it up, make sure any notches or splines line up, protect your hands (gloves) while you tighten the bolt. and you're back to cutting grass.
Cheerfuls.
Oct 19, 2015 | Craftsman Garden
Blade will not disengage on Craftsman GCV160 lawn mower.
that type mower the blade always turns when running .
May 07, 2015 | Craftsman Garden
How to remove a stuck bolt on blades on riding mower.
The blade bolt can be very difficult to remove sometimes and will require an impact wrench. If that doesn't work, you will need to heat up the nut only with a Ox/Acetylene torch, then it will remove easily. Do not heat the nut too much or it will ruin the thread on the spindle when it comes off. Remember to heat the nut only.
Aug 06, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Change blade on gas lawnmower
varies slightly as u didnt give model, i run front wheels onto car ramps and block rear wheels, then in middle of blade is a large bolt hold blade with leather glove and unscrew, put new one on and tighten,
Jun 09, 2012 | Craftsman Garden
Is Trying to change blades. I got the nuts loose but now they just spin in place instead of comming off.
Blade should be held on with a bolt, lock and flat washer. When installing be sure blade is alingn wit star on spindle.
May 03, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Replacing blades
It is standard threads and should turn left.
May 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
42 deck craftsman riding mower. how do you get blades off? md 91721880.
On most riding lawnmowers, you can remove the blades reaching underneath the deck while the deck is set to its highest position. This may not be possible on lawnmowers with three blades; however, most 42 inch mowers have two blades.
The blades are usually held on with either one or two bolts (on each blade). Oftentimes, too, there is a lock washer underneath the bolt.
If you have auto ramps, it might help to push the front end of the mower up on the ramps. This can give you more room to access the blade bolts.
If the blades have not been removed before, those bolts can be on really tight. You might need to use some kind of breaker bar on your wrench to give you more leverage.
Oct 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Changing out the blades...are the attachment bolts reverse thread or normal, i.e. clockwise to tighten?
Should be clockwise to tighten, use some "PB blaster or Deep Creep" penetrating oil on the bolts before trying to take them off. It will help.
Sep 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman LT1000 Parts manual
find every part you need on amazon here Amazon com Craftsman LT1000 Parts . take a look and enjoy
May 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor Logo
183 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
