Question about Denon AVR-4308CI Receiver
115v home cinema in 220v area
Recently moved from US with new denon 4308ci how can I set it up for use in 220volt land?
Thanks
  • 3 Answers
If it dosn't have a switch on the back to run in 220 I thought it did ??
then you will have to use one of those huge transformers they have over there and run it at 120
Posted on May 09, 2008
No sound from Denon AVR 988
make sure the TV audio setting is set to send sound through to the Denon not just out of the TV speakers, you wont be able to do both
Mar 17, 2014 | Denon AVR-988 7.1-Channel Multizone Home...
Ping/Green Bars on TV Display
I would first check and replace the cables to make sure you have clean signal. If that all checks out then I would consider putting in an amplifier in line to boost your signal. What is the distance you have on the cables all combined? Another thing to check in troubleshooting is to remove everything (cables) except the unit you are experiencing trouble with. If after all of this I would say your connection to your component itself is suspect.
Jan 27, 2014 | Denon AVR-4308CI Receiver
My DENON AVR-4308CI HOME has no sound. Everything comes on as it should and unit looks great but no audio comes out. It's had off and on issues since I bought it, but firmware helped with some. Now, no...
This may require quite a bit more info. Verify that there are no shorts in the speaker connections to the Denon - it has a short detection circuit that will shut down the audio amps in the event of a short. If you are using optical or coaxial digital input for you audio - verify that the correct digital input has been assigned to the component selected on the Source Select dial: Menu > Source Select > Assign > Digital. If this is an HDMI connection go into the HDMI setup menu and select Audio: AMP: Menu > Manual Setup > HDMI Setup > Audio > AMP. If it is set to TV the audio passes through the AMP without being decoded and goes to the TV instead: there is no 'Both' setting.
Oct 26, 2013 | Denon AVR-4308CI Receiver
Hayward super II wiring
move so both terminals are used sometimes they don't line up put on 220 then move to other position
Jul 24, 2012 | Hayward Super Pump 1 1/2 - Hp for In...
Is there anyplace that has denon schematics listed for free. I need them for models, AVR-4308CI & AVR-2307CI. Thanks, Lynne
send me your email address to www.yam_man_dan@yahoo.com and will email you them tomorrow,, put in title models make required to avoid spam..regards..yammandan.. have all teac denon yamaha manuals...regards yammandan
Aug 19, 2010 | Denon AVR4308CI
Were can I download a swedish manual for Denon AVR 4308
HI,
This was the closest could get on the user manual for this device.
http://www.denon.co.uk/site/popup/index.php?p=pdf&Pid=340
Thanks
proton
Aug 02, 2009 | Denon AVR-4308CI Receiver
DENON AVR 4308CI
SORRY, I WANT HANDS-ON SERVICE HERE IN MY CONDO.
Aug 23, 2008 | Denon AVR-4308CI Receiver
Input signal clicks on and off 4308ci
When you say the the input clicks on/off, does the sound cut out? I suspect that the protection circuit is kicking in. Can you please post the connections you have? # of speakers connected etc?
Thanks,
Dan
Jun 10, 2008 | Denon AVR-2106 Receiver
On screen display does not appear
Same problem, thanks for the solution -- resetting power solved it.
Mar 02, 2008 | Denon AVR-4308CI Receiver
Denon AVR-4308CI Receiver Logo
119 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
