Question about Refrigerators
The fridge builds up ice and stops the fan from spinning. Then the temputure changes. I take the backing off the inside of the fridge defrost it, Two days later the fan starts scrapping aginst the ice then builds up more and the fan stops. Theres obviously some thing thats soppost to stop the ice from building up just not sure what it is. Could you help please?
  • 503 Answers
The defrost circuit has failed. Typical failures are the defrost heater has opened, the defrost timer if equiped, is not advancing or the defrost thermostat is open. To check the heater, melt the ice, and use a meter to check if the heating elements are open, if they are, then you will need to replace the heating element.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Sep 01, 2010
Loud "clattering" noise from freezer area when refrigerator runs
There is a fan in the back of the freezer that runs when the compressor is running. It sounds like you have ice build up around the fan.
You could have one of these problems: (Sorted by most likely to least likely)
1) Auto Defrost timer, defrost bi-metal or defrost heater is defective - the unit will go into auto defrost about twice a day, if this fails you will have lots of ice built up around the cooling fins and sometimes on the fan. Pull the back off the inside of the freezer and check for ice build up around the cooling fins, there should be none or very little if its running normal.
2) Bad door gasket - if the freezer door is leaking warm moist air inside the freezer it could be condensing around the fan causing ice (you will also see ice build up on things inside your freezer too).
3) Plugged drain - the drain leads from the freezer down to the drain pain under the fridge. If this is plugged ice will build up on the bottom of the freezer and potentially around the fan.
Apr 01, 2013 | Kenmore Refrigerators
E442B Fridge is not cold & some ice build up in fridge. How do you remove the back of inside of freezer to check ice build up there?
don't mess about with it just remove items and get a new one sound like its leaked it's gas (BUT DON'T PANIC) its not harmful and its not going to blow up! you could call a engineer but a lot of the time your just as good putting that money towards a new one
your friendly domestic appliance engineer chris
Dec 05, 2011 | Refrigerators
Why has my fridge stopped working but my freezer still works its Hotpoint mistral plus
Possible that there is block on the air passage from the freezer fan which can be due to frost or failure of the fan.You need to check if there is free flow from the fan, also the setting of the fridge temperature.
Nov 26, 2011 | Refrigerators
Tempreture on fridge too high ice build up in fridge mahes noise like a tractor
Your automatic defrost cycle may not be working. Feel the walls inside and if they are hard solid you have ice build up and the fan is hitting the walls or ice making the noise. Unplug your fridge for 2 days and let the ice in the walls melt. Put towels on floor to catch water. Plug it back in and it should run fine for a couple of weeks until the ice builds up again. You have a bad timer and it isn't letting the defrost cycle come on. Defrost cycle are heating elements that melt the ice build up and runs about 10 mins once a day or so. This will give you time to check if an afforable repair can be done or a replacement fridge.
Jul 11, 2010 | Samsung Refrigerators
My hotpoint ff187e fridge is not cold, the freezer is working but getting a build up of ice which i have defrosted. tried turning off. when i open the fridge does not feel cold,not sure if the fan is...
we had same problem,apparently there is no such thing as a frost free fridge/freezer, you have to turn your appliance off for at least 3 days because the freezer has a build up of ice which stops the fridge from working, you must leave it switched off for this time otherwise it will just ice up again.
Nov 09, 2009 | Jenn-Air JCD2389G Side by Side...
Warm fridge cold freezer
Hi,advance thermostat setting, to get colder , it's possible you got defrost problem, is there excessive ice building inside back of freezer? to determine if you have a defrost problem, unplug ref. for about an hour,let it defrost, let all ice melt away, it's better to remove your produce, keep doors open to speed up defrosting, after defrosting and cleaning plug back your ref, and let it work for another hour, and check result, if it's o/k, put back your produce, let me know, during hot summer months, regular use (opening) of ref, could cause excessive ice build-up evap. if after defrosting and cleaning ref. work good for 3 to 4 days, but start doing the same thing, let me know, it means you got a defrost problem. also check your thermostat, but first defrost and clean it, that could just be your problem. good luck.
Aug 13, 2009 | Refrigerators
Ice building up in fridge
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Jul 12, 2009 | Refrigerators
Fridge is not 'freezing', Looks like fan stopped working
could be due to ice build up jamming the fan. take back panel off and check for ice. if ice present the defrost system has failed. also on some models, the fan stops when door is opened. check door switch is operating
Mar 22, 2007 | GE GSS25JF Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
