Question about Makita 10" Miter Saw LS1030N
I took the blade guard assembly off in a misguided move to clean it. I can't figure out how to position the spring pin in order to engage the cover. BIG project lined up for the weekend-need it working and safe by Sat. Model S1030
    Novelist:
  • 157 Answers
Hello. Just joined the staff here and found your question, sorry it's taken so long to get a reply. Should the issue still exist, or if any others crop up, here is the link to the manuals for this model.
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=370
Posted on Apr 05, 2011
How to I fix a Ryobi Miter Saw Blade Guard which is not retracting?
Sound like a piece of wood may have driven the arm up which operates the guard, if you remove the screws holding the guard support plate to the saw you should be able to remove the guard assembly, the arm can then be re-bent down on the end so that it meets the angled plate on the back of the guard and pushes the guard through the entire stroke, the other reason could be a damaged guard, when the centre screw is removed the plates can be removed from the guard, note how the spring and plates are assembled prior to dismantling, check the inside centre of the perspex guard and ensure the 4 protrusions which engage with the drive plate haven't broken off, if sow the guard will need to be replaced, this may now be an obsolete part , if so purchase a Makita guard as they are the same
Jul 18, 2015 | Ryobi 10 In Miter Saw With Laser
Ryobi TSS100L blade guard spring
I think what you are refering to is a circlip washer , and can only be
fitted with ( CIRCLIP PLIERS ) do you know any Michanics or Engineers as they are bound to have a set in their toolbox ,on the other hand you
can buy them. What they do is work in the opposit way normal pliers do
when you squees the handles together the jaws open,therefor opening
the (CIRCLIP ) and allowing you to place it over the pin and into the
recess. Hope this has been of some hellp goodluck T.C.
Mar 29, 2013 | Ryobi Saw. 13 Amp 10 in. Sliding Compound...
Makita
I don't have this particular model in my shop right now but almost all circular saws work like this. From the blade side of the saw, the spring attaches to a hole in the blade guard usually around the two to three o'clock position. With the blade guard correctly positioned on the saw, wrap the spring clockwise around the bottom of the hub and back up the nine o'clock side. There is another hole or tab inside the top of the upper blade guard somewhere around the twelve to two o'clock position. Hook the end of the spring there and test the guard for free movement throughout it's range of motion.
Aug 06, 2012 | Makita Bare-Tool BSS610Z 18-Volt LXT...
Found large spring at end of cable unattached lying on top of deck cover. Where does the spring attach in order to engage the blades on the riding mower? The lever is very loose and when checking, I found...
There are 4 pulleys on your deck. Two for the blades, these are the big ones on the outsides. To the insides there are two, one on left side is an idler and the one on the right is a tenioning pulley that hooks to the blade engage lever throught the cable you found. Look on top of this pulley and see if it has a piece sticking up. If so the spring at the end of the cable attaches here. Slide it over. You also need to find the clip that goes through the little hole in the end that keeps it from sliding off. Make sure that the cable is properly routed and attached near the back of the deck. If it is still attached, good, if not you will have to find that pin also.
If this is helpful, please rate.
Jul 10, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I assemble the blade guard for my Makita Miter Saw Model LS1030? I accidentally disassembled the guard it when changing to a new saw blade. I cant figure out how to get the tension spring back in...
lay the spring into the plastic safety cover, you will see a catch for one portion of the spring, the cover plate goes over it and there is a tab on it to catch the loose end and then the center plate which screws on to hold everything in place, check by turning the plate that holds it onto the saw for free movement. You can go to makitausa.com and in the header area on the right type in your model number ls1030n and you can download or look at a breakdown to see what I am talking about. Let me know if you need more assistance, just found your question.
May 01, 2011 | Makita 10" Miter Saw LS1030N
Can't find my owners manual. How do I change the blade. Bolt hits on a guard that covers the arbor. On a DW713 combination saw.
Removing the Blade
1. Unplug the saw.
2. Raise the arm to the upper position and raise the lower guard as far as possible.
3. Loosen, but do not remove guard bracket screw until the bracket can be raised far
enough to access the blade screw. Lower guard will remain raised due to the position
of the guard bracket screw.
4. Depress the spindle lock button (Fig. 3) while carefully rotating the saw blade by hand
until the lock engages
5. Keeping the button depressed, use the other hand and
the wrench provided to loosen the blade screw. (Turn
clockwise, left-hand threads.)
6. Remove the blade screw, outer blade clamp, and
blade. The inner blade clamp may be left on the
spindle.
Installing a Blade
1. Unplug the saw.
2. With the arm raised, the lower guard held open and the
guard bracket, place the blade on the spindle against
the inner blade clamp with the teeth at the bottom of
the blade pointing toward the back of the saw.
3. Assemble the outer blade clamp onto the spindle.
4. Install the blade screw and, engaging the spindle lock,
tighten the screw firmly with wrench provided. (Turn
counterclockwise, left-hand threads.)
5. Return the guard bracket to its original position and
firmly tighten the guard bracket screw to hold bracket
in place.
WARNING:
• The guard bracket must be returned
to its original position and the
screw tightened before activating
the saw.
• Failure to do so may allow the guard
to contact the spinning saw blade
resulting in damage to the saw and
severe personal injury
you can download a manual at: http://www.dewalt.com/tools/machinery-miter-saws-dw713.aspx
Jul 20, 2010 | Garden
I am missing the part that brings the guard back when you lower the saw blade
I am assuming that you have some type circular saw?
Most popular saws use a spring to return the guard,with the saw unplugged raise the guard and see if the spring is there(you may need to take off the blade) if it is not there,replace with proper spring.one end of the spring will hook onto the fixed 1/2 of the guard the other to the front of the moving guard(consult manual if possible).once this is done insure that the guard mover freely and is not in the way of the blade.Replace the blade in proper direction check guard again for proper travel,make sure everything has been re-tightened .
If the spring is there check for material build-up or debris that is causing
guard not to move,remove blade clean debris or obstruction,replace blade and check for proper operation.Also visually inspect where the moving guard is attached to the saw for any unusual marks or wear this could be a sign that some type of unsafe situation exists,if this happens refer to a pro to fix or buy new never use a saw without a properly working guard,it took 141 stitches to repair my friends leg.
Sep 28, 2009 | Hand Tools
I'm trying to figure out if I need to hold the lower blade guard up while the saw is running...there is no lock for it
No you do not need to holde the lower blade guard up. It should be spring loaded and move upward as it engages to piece being cut. depending on what you are cutting, you may need to hold it up to start the cut, but then it can be let back down while cutting. It is a safety feature designed to keep as much of the blade covered as possible during use.
Jun 27, 2009 | Ryobi 18v Cordless 5-1/2" Circular Saw...
I took the guard off the 10" Makita Mitre saw (spring loaded)!
Oh, you got it off. I bet you can put it back on again.
It's much easier if you take the blade off first. Then you'll be able to reach inside when you need to. Be patient, don't force it, and make sure when you get the spring reconnected properly that the guard moves freely out of the way when you chop, and returns when you raise the saw back up.
It's a bit of a trick, but I bet you can manage it..It's been awhile, but it seems to me there's a way to get the bolt started before you engage the tension on the spring...I'd have to have it in my hands to say exactly.
Here's a link to the exploded parts view at the Makita site, just in case. And it might help to have an extra pair of hands, or a piece of duct tape to hold the guard in place when you go to put the blade back on.
Apr 10, 2009 | Makita 10" Miter Saw LS1030N
2000 pontiac montana wipers stuck
This has happened a couple of times on my 1999 Pontiac Montana. Here's what I did to fix. Open the hood. Remove the shield over the the wiper cam mechanism on the passengers side. This is easy to access. Road salts and other dust and dirt gets in there and causes the sticking problem. Spray WD-40 in between the parts. Get in there with that little red spray straw and saturate it good, flush junk out. Get in the car and try the wipers. If I remember, you might have to manually place that little knob or lever on top of the cam in the opposite position to get it to resync, but try it first. Be sure the wipers are off when you're spraying the WD-40 so you don't injur your hands. I've had to do this twice and it worked both times.
Dec 30, 2008 | 2000 Pontiac Montana
Makita 10" Miter Saw LS1030N Logo
220 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
