Question about Sylvania 6427TE 27" TV
My Sylvania 6427TE 27" TV kept losing its color, until now there is only black and white, and sometimes blue shows up. the picture quality is fine. the color is the problem.
  • Sylvania Master
  • 17,130 Answers
Possible fault can be in the CRT base of the TV or the fault of the Chroma IC/ Crt Drive connecctor.
The CRT board is the picture tube rear conneccted to a printed circuit board. Normally there are many transistor drivers , three for the three seperrate guns and two for the purity correction.
There could be a fault if one of the transistors are off with a dry soldering as you are having an intermittent fault. So the best way out is to solder this board and check.
If the fault is staying then check the line going to the main board- the rribbon wire cluster. You will notice a large IC near to this wire connecction with a lot of passive ccomponents around it. Solder the IC and if you find a Crystal around this section solder the area around it. Put the sett on- But take presaution when set is on not to touch circuits- and tap gently on the board. If there is colour flicking look for dry solder joints and solder.Repeat this work with caution not to bridge any tracks.
Finally we can also suspect the picture tube. If a gentle tap is bringing the colour back it can be the tube, you can use a regenerative apparatus to remove short and maybe get the tube in good order.
But that will be the last thing as I suspect the fault can be the CRT base board.
Please check and comment.
Posted on Sep 01, 2010
Game mode not showing any picture when i plug in my xbox 360
Check the input selection settings to TV. Refer its user manual for details.
Apr 25, 2014 | Sylvania 6427TE 27" TV
White line horiziontaly thru screen...rest black
The "Drive" circuitry has failed.
Generally NOT an expensive repair.
Take it to a reputable repair shop and get a "Quote" for repair.
GL.
Jan 18, 2010 | Sylvania 6427TE 27" TV
Tv went to black and white
It may be a wire has come loose. Check your video inputs. Especially if you have animals or small children. On certain video inputs you lose color if one wire comes loose.
Jul 20, 2009 | LG RU-44SZ63D Television
Screen got wide; nasty acrid smell like chlorine or ozone started
One or more electronic components was burned or deteriorated inside the tv.
Replace the TV.
May 24, 2009 | Sylvania 6427TE 27" TV
My componet/av only shows black and white on my vizio vp422
The 37" Vizio I just bought has a very confusing feature where the same input can be used as either the Y channel of the component or the full video channel for composite. If you plug a component source into the TV and then select the composite input ("AV" on the remote), you will see a black and white version of the full component signal (makes sense as the Y channel is just the luminance component). As sad as it is, I was stumped by this for a while until I happened to hit "COMP" and got full color. FWIW, the manual warns about this, but it really doesn't emphasize the point. I wonder how many returns they get because of this.
Mar 16, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
TV picture is not good
from what your describing it sounds like a resolution or ratio setting on your t.v. you can change these setting on your cable box and t.v as well this seems to be the setting on your t.v. since you have already unhooked the cable box. if changing the settings doesnt resolve your issue you may have some failed components on the pc board that could be repaired by a repairman v/s purchasing a new one. hope this was helpful....
Dec 16, 2008 | Sylvania 6427TE 27" TV
Xbox
I have the same problem with a 6420ff sylvania tv with a xbox 360. I plug the red white yellow into the front of the tv and it wont come on.
Oct 16, 2008 | Sylvania 6427TE 27" TV
Tv screen
hi there, working sometimes means there's a lose solder at the vertical section. see the vertical ic, check the board for some lose connection and cold solder. do some test. ty
Nov 09, 2007 | Sylvania 6427TE 27" TV
Sylvania 6427TE 27" TV Logo
48 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
