Question about Gateway 450ROG Notebook
Gateway 450 ROG will run only on battery.
Gateway 450 ROG gets no power from ac adapter and won't charge the battery. Have tested the adapter on another laptop and it is working. Only way I can use it is to use another 450 to charge the battery, then swap batteries when mine runs out. Support says it's a loose connection between the power supply and motherboard and motherboard must be replaced. Sound right? Is it repairable/worth repairing?
  • 2 more comments
  • mototoad Aug 26, 2008
    The power connector on the motherboard needs resoldered. Same thing happened to my Fiance's laptop. Remove the 500 screws to gut it and resolder it. Tip for gutting... pop the plastic strip that the power button is in off 1st. Use a knife on the left side and pop up (it snaps in). Then take out 4 screws for the keyboard... then the other zillion... plan on a few hours of fun.
  • hank watkins Oct 16, 2008
    dead set
  • dlrbond Nov 05, 2008
    My problem is similar. When I plug in the power supply I get no lights of any kind. The battery is probably dead but I have no other laptop to use to charge it. After pulling it apart I found a small component on the motherboard labeled "PL2" (near the power connector dock on the motherboard) that has the bacalite (sp?) coating pretty much burnt and crusty. My thought is that this component needs replacing but a) is it worth it and b) would this be a part that a typical computer repair shop could replace?
  • reckma Dec 01, 2008
    I have the exact same problem, but will not be paying anything to fix it.
    Scholar:
  • 110 Answers
If it's still under warranty, it's definitely worth repairing. If not, get them to quote for the repair they say it needs before agreeing to it. If their quote is anything close to the current price, I would say it's not worth it.
Posted on May 26, 2008
Why won't my gateway MD78 power on?
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Gateway MD78 AC Adapter 65Watt 19V 3.42A Option
Replacement Gateway MD78 MD7800 AC Adapter 90Watt 19V 4.74A
Nov 29, 2012 | Gateway Computers & Internet
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
Power adapter is good, but Gatway MX6025 will not power on. It does power on briefly with battery installed. I've tested the ac adapter with a multimeter and it appears to be good. Green light on,...
Try to check with another adapter if possible.
The connector of the laptop might be damaged. so the battery is not charging and also not staring laptop on AC power. Check the ac connector of laptop.
Jun 08, 2011 | Gateway MX6025 Notebook
My AC adapter suddenly can't seems to be able to charge my battery. Please kindly advise
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced. Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
May 08, 2011 | Compaq Presario CQ40 Series Laptop Charger...
My power button on my rog is showing orange the fan is running when I turn the laptop on but nothing else is the orange light telling me that the hard drive is bad, the memory needs to be changed, or is it...
Remove the dc battery, and unplug the dc adapter.You will hold or press the power button for 40 seconds.Now you will get positive result,when you plug the adapter to your laptop and the Battery also.Almost 80% laptop can solve for this problem through the process.You also change the ac adapter for ensure,about your adapter ok or not.
Hope it help you.
Jan 06, 2011 | Gateway 450ROG Notebook
Gateway lt21 netbook not charging
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 13, 2010 | Gateway Computers & Internet
My gateway mt6840 does not read my new battery
Have you tested your power supply to confirm it's sending out the right amount of current.A simple ac tester is all you need.On the back of your power brick it will tell you your in-put and out-put voltage requirements.If your ac adapter tests good your new battery is probally the problem.
Jun 02, 2010 | Gateway MT6840 Notebook
I've had my Gateway M-6843 Notebook for about 18 months. Since the day I bought it from Best Buy, the AC adapter port has been finicky. I'll be using the laptop with the adapter plugged in and the...
This problem can be caused by mainly two different things. It is either the AC Adapter itself and has a short in it, or sometimes it is caused by the Power Jack inside the laptop. Are you familiar with how to read a voltmeter? I can walk you through testing your adapter. If it is either issue, I would recommend trying to fix through warranty if possible, because the power jack repair can be expensive. If you need to replace the AC adapter, I recommend a genuine adapter, as universal adapters and cheap knockoff brands will cause issues with your laptop and usually not last very long.
Dec 11, 2009 | Gateway M-6843 Notebook
Gateway 450ROG Notebook Logo
325 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
