SOURCE: Washer will not Spin during SPIN CYCLES
YES, the door. I read up all I could and told my service tech I thought it was the door. The tech mechanic initially said it couldn't be the door since all the other cycles funtioned normally. After changing both the computer on the panel and inside, he finally realized it was the door.
Once again, if your washer does everything but spin, it is a door lock problem. Note: The door does lock, but does not send the correct signal allowing the washer to spin!!
Mike
[email protected]
SOURCE: Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
SOURCE: My Maytag Neptune washer won't spin during the spin cycle.
I'm having the same problem...Does it say LR?
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
does the unit drain
yes, the unit does drain.
yes, the unit drains
