Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
Cannot record, reverse or or pause anything I am watching
    Novelist:
  • 185 Answers
Hello! Dan Busa with DISH Network customer servuce here. If this is still persisting try unplugging the receiver for ten seconds.
Posted on Jan 07, 2011
How long is it safe to pause a Samsung smart tv for. My husband says I will ruin it by pausing it
How big is its hard drive memory ?
When you pause live tv the tv starts recording the live tv on the hard drive it has. So a few hours would be normal but a few days would use up hard drive space. It deletes the recorded tv as you watch it back.
Mar 14, 2017 | Samsung Televison & Video
The recorder if not recording and when watching previous recordings you cannot rewind or forward wind or turn off
for recording plz click this link may be it helps you
http://windows.microsoft.com/en-US/windows7/Record-TV-in-Windows-Media-Center
and for the change channel and pause live tv you change you remote set. may be it has some problem.
Dec 15, 2011 | Humax Televison & Video
Trying to dub from dvr to vhs vcr
Is L2 for composite video (yellow) or S-Video? Try watching a video on L2 with the composite video plugged into the back of your TV, if it works, then do the same with the DVR, if that works, then run the DVR composite video into a receiver, then the L2 from the VCR to the video out on your receiver. It's possible that the VCR won't record anything that isn't an applified signal. That's what the receiver does.
Oct 01, 2009 | Sony RDR-VX555
94' jeep grand cherokee trans. delays in reverse
Hi ray_c_brown, This pause is determined by a time lag test, and you can check this yourself with a stop watch.Engagement time in "D" range should be a maximum of 1.2 seconds and the engagement time for reverse should be a maximum of 1.5 seconds. So with your vehicle warmed up and assuming curb idle speed is correct set the park brake,make sure ac is off (air cond) shift transfer case to 2H or if it is a NP249 transfer case leave in 4H,put your vehicle into neutral and set your stop watch shift to Drive and record time repeat this a couple of times and do the same with reverse,as you said the delay is with reverse so if it takes longer than 1.5 seconds here are a few things it could be:shift cable adjustment,low line pressure,worn direct clutch, first/reverse brake worn or a worn or damaged overdrive clutch.Hope this helps you good luck :)
Nov 11, 2008 | 1994 Jeep Grand Cherokee
Cd rewritable player recorder tascam cdrw4u
I never had that problems. I have been using it over five years. Does it play commercially made CDs (the ones you bought at the store)? Panel shows track numbers and sound volume? Can you hear it by using a head set (phone volume control turned up? If so, now recording part, do you have input select correct (analog or digital)? Input cable(s) into right connector(s)? When you press "record" button, does it put into "pause" mode? Can you watch the incoming sound levels when it is on "pause" mode? Can you start the recording with remote's fader button or play/pause button on the machine? Good luck.
Jun 09, 2008 | Tascam CD-RW4U CD Recorder
Hello! My Philips DVDR5350H/05 randomley records for 6 hours. The only way to stop this, once the recording has started, is to go into the system menu and select the option to remove the time shift...
Hello. This is not a fault. The DVDR5350H's Hard Drive (called Time Shift Buffer) begins recording (for up to six hours) as soon as the unit it switched on and only clears the 'temporary' recordings when it is switched off or you switch to 'Cam' mode on the remote control.
Like Sky+ and Freeview+, the continuous recoding enables you to save, pause and rewind live TV (this could also apply to Freeview or any source that you may have connected to the EXT1 and EXT2 SCART sockets. In other words, if you are watching TV or anything connected to the 5350 while it is switched on you can keep it without even having pressed record in the first place (pressing OK on the remote control will show you how).
It is normal for all HDD recorders with a 'pause live TV' function to record whether asked to or not.
May 27, 2008 | Philips Televison & Video
DHG-HDD250 problems when recording
When I'm watching a recording program and recording a program I can't fast forward, pause, stop nothing works until the program that is recording stops.
I reset the machine, but it did not help.
Feb 26, 2008 | Sony DHG-HDD250 200-Hours Video Recorder
Help! Stopped Recording
Do you have a remote? Some camcorders you have to hit the record pause button on the remote and then hit pause. It then begins recording. I hope this works for you.
Jul 13, 2007 | Samsung VP-D10 Mini DV Digital Camcorder
My remote doesn't work when recording.
I have the same problem with my dvr. I went to tech support at sony. The tech spent a lot of time researching the problem. I had to leave so I told him to email me when he had some information. It's been 3 days now and I havent heard from him yet.
Mar 01, 2007 | Sony DHG-HDD500 400-Hours Video Recorder
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
42 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
