Question about Jenn-Air JES9750 Electric Kitchen Range
JENN-AIR JES9750BAB - preheat for bake takes TOO long - very slow. It was performing well but just observed issues this evening.
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: jenn air jgr8850adw won't bake
This usually is an indication of a bad igniter. If this is the standard glow type igniter, it could appear as if it is working, but may not be providing enough current to open the gas valve. This is a safety feature on gas ovens. The gas valve requires a current potential of .32 to .37 amps through the igniter before it will open and allow gas to flow. This prevents gas leakage if the igniter fails to light. The reason your broiler works is probably due to the fact that the broiler gets used less and the igniter is probably in better condition. You can test this theory, if you like, by swapping the igniter for the bake and broil burners to see if the symptoms change. Or, you can simply just replace the bake igniter with a new one. Make sure you secure the power before attempting, though. You shouldn't have to turn off the gas for this. Chances are that's all it is. I hope this helps you.
Posted on Jul 14, 2007
fridgetech
  • 473 Answers
SOURCE: bake part of kenmore not working seems to take to long
Chances are the oven ignitor will need to be replaced.  Look and see if it glows.  If it does then it is weak and not opening the gas valve to lite.  Let me know what you find.
Comment by fridgetech, posted on Oct 20, 2007
Should be able to remove the bottom drawer and unplug the ignitor from below.  Or you can cut the wires on the old ignitor and splice the new one in using ceramic
Posted on Oct 20, 2007
ngfam1
  • 639 Answers
SOURCE: problem with oven preheating
Hi, I'm Neil
It is a fire hazard! Be Careful!
It's a gas regulator or thermostat
This time you will have to call the the manufacturer for service!
If it's under a year old ,your under warranty and it will not cost you anything!
Please give me a solution rating here!
Thank You
Neil
Posted on Aug 24, 2008
SOURCE: Jenn-Air JDS8850BDS control panel malfunction
You need a new control board. I bought similar range in 2004 and I just got my 3rd control board. Heating the oven over 400 degrees and using the self-clean function kills the board.
Posted on Aug 12, 2009
Funny - didn't ask about a slide in electric kitchen range - was asking about my Jenn Air Stove. You deal with them, correct? Have a Jenn Air WW2780B that I can't seem to get working. It started...
I had a customer with the same problem last month and I believe it was on the same model as yours. Let me look in my database and I will get right back to you.
Warmest regards,Richard
Nov 01, 2011 | Jenn-Air SVE47100 Slide-In Electric...
My jenn-air gas oven works when i put the broiler on but the oven will not come on
i would replace your bake ignitor, as an oven cycles the broil ignitor and bake ignitor on/off to preheat the oven.. if ur bake is not coming on i would replace it, hope this helps
Feb 12, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Hi ,I have model jgs8850ads,it takes along time to preheat,about 40 min. what could this be? please respond.
is this a duel fuel with an electric oven..... the bake is the bottom and the broil is the top both cycle on and off to preheat the oven.... if ur lower bake element is burnt out then u woould expereicnce the problem u stated..... if u have a gas oven then ur ignitor or glow bar is probably burnt out....... either way it sounds like your bake element or bake ignitor has failed
Jan 31, 2010 | Jenn-Air JGS8850ADS Gas Kitchen Range
My Jenn Air JGS8850 takes over 10 minutes to preheat to, say, 400*. Is this normal?
In a word...Yes !
10 min. is actually a really great preheat time. I have many customers who would kill for that kind of preheat, most are between 15-20 minutes minimum to 350 degrees celcius, especially with the introduction of hidden bake elements in the last 10-15 years.
Hope that is helpful,
Good Luck :)
Oct 22, 2009 | Jenn-Air JGS8850 Gas Kitchen Range
The convection fan does not work anymore in any of the following situations: Convect bake, roast bake or quick preheat. What could be the cause? Can we get the electrical schematic for this...
This is your convection motor that's gone out. If you will call or email us, we;ll be sure to send the correct motor along with the schematic for your Jenn-Air range. This is an easy problem to solve so please get in touch with us soon so you can get your oven running right again.Remember...Thanksgiving is just around the corner, so lets get you cooling again real soon. We hope to hear back from you real soon,
Sep 29, 2009 | Jenn-Air JES9800A Electric Kitchen Range
Jenn-Air JES9750 Electric Kitchen Range Oven Heating Problem
One or both of your oven elements are likely failing. I would replace them both. It's not hard job.
Aug 19, 2017 | Jenn-Air JES9750 Electric Kitchen Range
Jenn air jgr8850adw won't bake
Jun 12, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air JES9750 Electric Kitchen Range Logo
199 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
