How do i determine the age of my central unit
  • 107 Answers
If you could place the Brand, Model# and Serial # on here then we can search that for you... thank you
Posted on Sep 05, 2010
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
How old is my Friedrich WallMaster WS08B10 Air Conditioner
The age of your unit can be determined from the serial number. You will find this serial number on the data tag located on the inside of the unit just below the control panel. If you will call the Customer Assistance Center at Friedrich, 800-541-6645, extension 260, they will be able to assist you with the age of your unit. Hours are Monday thru Friday 7:00 am - 6:00 pm, central time.
May 05, 2012 | Friedrich WallMaster WS08B10 Air...
My armstrong central air unit only has these # on it la 69486 can you tell me what the ton is a nd btu and age of it?
Based on these numbers there is no way to determine the age or the size of the equipment.
Sorry! James
Apr 05, 2011 | Heating & Cooling
Can you tell me tha age of a dryer if i have m and s numbers of unit if so m 110.72062102 s mr1304865 kenmore
The dryer is made by Whirlpool and its age can be determined from the serial number. The second character (R) is the year while the first 2-digit of the number (13) is the week on that year the dryer was made. The dryer was made on the 13th week of the year code R which is 2004. The dryer was made approximately on April 2004, about 7 years ago. Click on the link below for further details on how to determine the age of dryers and washers made by Whirlpool.
Determining the Age of Dryers and Washing Machines Made by Whirlpool
Feb 23, 2011 | Kenmore Dryers
Own Heir Outdoor unit (HC60A1VAR) condensing unit (central Air Conditioning Unit).ESTIMATED AGE IS 3+ YEARS. Local repair service says the condensor is cracked and leaking and non repairable. He(local...
Yes, as well explained, he is 100% right on the money. With a device of this age, I would expect it is way beyond repair and no doubt, not "Legal" with emissions etc.
In my professional opinion you should cut your losses and replace the unit, in it's entirety. This WILL be the safest and most economic way to effect a remedy for your problem. In the long run.
I realize that it may be a little costly to do so. But in the end it will save money and headaches.
Also you would have the peace of mind that a new and professionally installed system will give.
Trying to repair these types of older units, is like trying to drain a pond with a sieve... at best a waste of time and money. You see the new emission standards are pretty thorough and getting any older parts up to spec, as it were is near impossible, I am sorry to tell you.
Well good luck, and I hope you prevail.
Jul 28, 2010 | Haier Heating & Cooling
The central locking pump will not operate the 1999 polo
the central locking compressor located in the right side of the boot behind the panel with the light is faulty there are 3 plug in modules and 2pipes which are easily disconnected .a new unit costs in the region of £350+ but a second hand unit can be sourced from a breaker for e few pounds .but take care to get the age and model matched as the units may look the same but might not have the remote locking facility
May 10, 2010 | Cars & Trucks
My Rheem central A/C blower motor cycles on & off
Depending on age of Rheem they have a time delay relay. May be causing the problem. The time delay operates the fan. Try turning fan to continuous and see if it stays on.
Jun 07, 2009 | Heating & Cooling
Nutone CV-750
You need to determine if this is a problem with the hose or the unit. I would recommend plugging my hose in the wall sideways. This should make your central vacuum run continuously. If the unit doesn't cut on and off it is the hose. If it still cuts on and off it is probably the relay.
Jan 06, 2009 | Broan-NuTone CV353 Central Vacuum
Central A/C
Hello
This system uses r-22.
By law it will have to be recovered, it can not be bled in the atmosphere. Just FYI. Hope this helps you.
One way to determine what type of refrigirant you are dealing with is to let is set in a system that is not being run for 24 hours and use a pressure temperature chart to determine gauge pressure at said temperature.
Thanks
Zerko
Aug 30, 2008 | Heating & Cooling
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
