Question about GE Adora (DSF25KGTBG) Side by Side Refrigerator
I opened the freezer and freezer is not freezing, I found ice on the back wall .Both freezer and fridge will not cool. I tried to reset it now.
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 01, 2010
Why is my smeg fridge not keeping anything cool
Hi...the same thing has happened to me. My Smeg Fab28 refrigerator compartment has stopped cooling. The freezer still works. There was a build up of ice on the back fridge wall, and the milk was freezing up, so I turned down the temp. After the ice melted, I heard a bang like a bunch of ice had dropped. I turned the temp back up but it steadily stopped cooling even more. I decided to defrost the freezer, and had the power off completely for about 5 hours. When I turned it back on, the freezer worked, but the fridge is not cooling AT ALL.
Did you fix the problem and if so, how?
Thank you
Bev
Jun 02, 2014 | Smeg Refrigerators
Very noisy fridge, back wall freezing up
Possible bad freezer fan motor. I need more information such as brand and model number
Mar 10, 2014 | Samsung RS2630WW Side by Side Refrigerator
Freezer not freezing but cools like the refrigerator would. Refrigerator not cooling enough. the cover in the back of the refrigerator was off. I reconnected but the freezer still won't freeze
is the freezer fan running? is there frost on the rear freezer wall if so it would be a defrost issue. if no frost on freezer rear panel it would sound like a bad compressor or sealedsystem leak.
Jun 06, 2011 | Kenmore Top Freezer Refrigerator
Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Not as cold as it should be
see if there is ice on the back wall of freezer if so this is an automatic defrost problem timer heater or limit switch
Apr 17, 2009 | Whirlpool ED5SHAXM Side by Side...
Freezer compartment not cooling
Di a total defrost and remove the back wall cover from the freezer. Look for ice buildup in the cooling fins. If the air channel is blocked, you won't get proper freezing.
Mar 23, 2009 | GE Refrigerators
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Nov 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bosch frost free fridge freezer not freezing ice cream/pops at all and meat not totally frozen
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
GE Adora (DSF25KGTBG) Side by Side Refrigerator Logo
151 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
