Question about Kitchen Ranges
What would make a refrigerator freeze up in the frigerator section
  • Kitchen Ranges Master
  • 3,083 Answers
This website tells of the most common things that can cause this:
http://www.repairclinic.com/Refrigerator-Troubleshooting#Thefoodintherefrigeratorfreezes
Also, if you pick your type of unit, you will find more information.
Enter your model number on this site, and they have some great diagrams:
http://www.appliancepartspros.com/
Can be a bad thermostat, but could be other things as mentioned above.
Good luck, thanks for using FixYa, and hope this helps.
Posted on Sep 01, 2010
Whirlpool Gold side by side frigerator freezer ice and water not working, inside frigerator various places freeze, on certain shelves units only 5 years old
As far as the icing up sounds like your cross over have ice. Unplug and defrost even on frost free. Should solve both problems
mike
Dec 19, 2017 | Whirlpool Refrigerators
Refrigerator side freezing and cannot control temp.
099b99d4-9ea3-4dba-a2ca-6c92989fe8af.jpgLook and see if the air damper called a=> 5304482075 Temperature Control Thermostat is opening and closing after selecting a different temperature. This along with the termostat are what controls the fresh food section temperatures. I am here should you have questions, Thanks Sea Breeze
Apr 25, 2013 | Frigidaire Refrigerators
Fridge does not get cold during propane gas function only. Upper Freezer section does. Whole unit does perform and freeze and cold function fine with electric and generator function. Why only during...
According to the manual the following is the most likely items to cause that failure. But since it is only in the frigerator section and not the freezer section it could be the lower circuit board.
LP Gas
Orifice
Flue Baffle
Flue Tube
Burner
Lower Circuit Board
Sep 10, 2011 | Dometic RM2652 Refrigerator
Fridge and freezer are set at 7 and the fridge is cool but not cold and the freezer has not been able to freeze a box of freezepops that have been in (2) days, The back wall of the freezer has frost...
http://www.partselect.com/PS303781-GE-WR51X10055-Defrost-Heater-Bracket-Assembly.htm?SourceCode=1&ModelNum=HSM25GFRASA
WR51X10055 is the part number of the defrost heater and bracket assembly. Item #230 in the diagram. On this unit it is a plug in unit.
It is relatively easy to replace. Remove food from the freezer section, remove shelves, remove back panel. Unplug refrigerator. Defrost the unit by either leaving the door open to the freezer section or you can hurry it up with a hair dryer. After it is defrosted, plug in the new defrost unit, plug the frigerator back in and reattach the back panel, shelves and food.
Jun 10, 2011 | Hotpoint HSM25GFRSA
Friger too cold
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Sep 13, 2010 | GE Profile PSW26P Stainless Steel Side by...
It freezes the frigerator side
check for ice build up on the damper door located between the freezer and refrigerator compartments and make sure it can open and close as you adjust the refrigerator cold control,if so defrost it with a hair dryer and then try it for operation
Feb 20, 2010 | Frigidaire PLHS267ZA Side by Side...
Refrigerator is freezing
if you turn up the temp in freezer and down on frig side and frig still freeze's than more than likly you have a bad frigerator thermastate.
Nov 17, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerator is warm on the inside
hello mam
if the refrigerator is not cooling we should check the freezing coolant in the compressor and if necessary that should be refilled.
Jul 13, 2009 | Danby Compact Refrigerator DCR-101W
Refrigerator is freezing up inside at the top.
check the seal on the door it might be that because when the water vapor in the air gets in it will freeze on the top.
Mar 31, 2009 | GE Refrigerators
Kitchen Ranges Logo
80 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
