Question about Whirlpool 71001872 CNTRL-ELEC
I recently purchased part 71001872 for my Jenn-Air WW30430P. It came but it looks like the clip the ribbon cable is supposed to insert into is missing. Instead there is a row of bare pins where the black clip thing had been on the old part. I called Jenn-Air. Their solution was to call a certified repair person as they are producing the parts through a new supplier and they would not furnish instructions for the part. This would be an easy fix if the new part has the same clip. Any suggestions? I do have photos of the problem if that would be easier to understand. Thanks!
  • Official Brand Answer
  • 380 Answers
Paula_hansen, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Paul_hansen), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Posted on Apr 25, 2017
Some touchpad buttons don't work but some do. Cancel button for bottom oven doesn't work. Have to flip breaker to turn off. CLock works
Jenn-Air WW30430P Oven User Manual - ManualsOnline.com
fitness.manualsonline.com > ... > Jenn-Air Oven
Free kitchen appliance user manuals, instructions, and product support information. Find owners guides and pdf support documentation for blenders, coffee ..
Sep 24, 2015 | Jenn-Air WW30430P Stainless Steel Electric...
I need the Start Amprege for a Jenn Aire #WW30430P
phone jen air tech support daytime Eastern Standard time:
1-800-JENN-AIR (536-6247)
Dec 20, 2013 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn Air wall oven won't cancel / shut off . Recently replaced membrane.
Hey - the ribbon link from membrane to control is a tricky plug to get in right- double check this connection and let me know if it helps- Thanks- Ed
May 13, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Am negotiating a home inspection on a house with WW30430P Jenn Air Wall Ovens; neither of the doors close. Is there a solution?
There are several models of Jenn-Air ovens that had issues with the door closing. The only solution is to replace the door hinges (unless the doors themselves are bad, you can see this if you open the door, the porcelain on the door will be bulged and cracked right where the hinge joins the door). If the doors are bad, the hinges and the interior door panels need to be replaced. Hope this helps!
Dec 16, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn air ww30430p led controls are dim can't see temp. Need to change what part? and the doors never closed correctly
BrianGem posted a great solution back in May of '08, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board apparently has a weak spot in the
design, most likely heat related, (probably low priced components from offshore sources)
Fix: Replace heat damaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm lucky enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recommend changing sizes without design review for fear of overloading another component, however several other posts have indicated that a 35V 100mF cap has worked fine for them.
TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, Using as small a soldering iron as you can find De-solder it and replace with new, match polarity marks and don’t use any more solder than needed.
If you run into trouble drop me an e-mail to dltatsjc@aol.com and I’ll try to help.
Good luck.
Thanks for this site..
Link to Photo sequence of capacitor replacement (Captions still will not link):
http://picasaweb.google.com/dltatsjc/Photos?authkey=Gv1sRgCJPKv9CRgsXxNA
Sep 23, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
LED display does not light up. All other control functions seem to be working.
work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, De-solder it and replace with new, match polarity marks and don’t use any more solder than needed. TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
Good luck.
Jul 07, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Jjw9630aab panel is dim
See other posts regarding replacement of capaciter #C3 on control board, cost of capaciter approx 65 cents.
Good luck.
Mar 25, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Whirlpool 71001872 CNTRL-ELEC Logo
312 people viewed this question
Top Whirlpool Hardware & Accessories Experts
Joseph Mueller
Joseph Mueller
Are you a Whirlpool Hardware and Accessory Expert? Answer questions, earn points and help others
