Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
Machine shuts off out of the blue and buttons on the printer are not functionable and do not work when touched...It needs to be re-started several times at once in order for it so stay out and then it wil automatically shut off....
    Sniper:
  • 56 Answers
That is a formatter issue (the motherboard). Nothing can be done unfortunately. But HP is giving 2 years of warranty from the purchase date if this specific issue arise.
Posted on Sep 07, 2010
How can i reset my canon printer error code 007
Error code is regarding fixing unite.
1 check Teflon sleeve in fixing , if found damaged than replace,
2 check lower pressure roller and end rubber gear if found damage replace it
3 now start copier press buttons in following sequence
Addi. function *
than 28
again *
than on panel its display " COPIER"
touch it, than again touch on "FUNCTION"
Than Touch on "ERR"
than Touch "OK"
than switch off machine and again start.
machine will ready
Sep 26, 2014 | Canon iR2018N
Touch screen on minolta bizhub 200 not working all the time
Need a new touch screen.One other option. Push utility/counter meter count then press stop 00 stop 02. Places machine in maintenance mode. Then press the utiltiy/counter will see maintenance mode press that find touch screen adjustment. follow the screenthen press start. T clear maintenamce mode and flashing start button. Power off machine main power left side of the machine to the rear.
Feb 07, 2014 | Minolta bizhub 200 Copier
E000110 0001
press "addtional function button" then 28 button then "addtional function button", new box will come after that clear all jam(touch all things then touch ok button , one by one) & restart the machine.
May 19, 2013 | Canon ImageRunner 2270 | IR2270 |
CANON IR6800CN ERROR:E000078-000; HOW CAN I REMOVE IT IN ORDER FOR THE MACHINE TO WORK PROPERLY.
you can follow this steps
press additional function 2 , 8 and additional function
then touch on copier,
touch in function
touch on clear
touch on ERR press ok.
touch on DCON press ok
touch on RCON press ok.
press reset button 4 times
and restart machine
Apr 11, 2011 | Canon imageRUNNER C6800 Copier
ERROR TO CANON IR6800CN E000078-0001 what does it mean? the machine stops to work
you can clear this error by this steps
press addition funation 2 , 8 and additional function
go in Copier
press function
press on clear
touch on DCON press ok.
press reset button 4 times. and restart machine.
Apr 11, 2011 | Canon Office Equipment & Supplies
E00002-0000
Just entering service mode by pressing add. function, 2 & 8 and add. function, touch copier option, then function, then clear and touch ok button. your problem will resolved. if error again come then you need to replace fixing film assambly.
Jul 05, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Turn on ok. Press start and spin light blinking and beeping.
Several problems were found
1. the touch panel PCB board had tracks which were damaged by moisture and had it repaired for $50 (Aus); this affected the advance function on the washing machine.
2. Controller motor was replaced with a rebuilt one (since the touch panel kept on shutting down).
3. Make sure that the wire holding the harness reed switch is tight (this I think controls the level in the washing machine).
Apr 13, 2009 | Fisher Washing Machines
Resetting lbp fuser
you need to do a lbp fuser reset and lbp error log clear
fuser reset
function- 7- monitor button 4 times slowly- then press * "start" button, should say service mode, then press 7- start- down arrow - start- then yes
log clear
function- 7- monitor button 4 times slowly- then press * "start" button, should say service mode, the press 6 - use the down arrow to get to lbp log clear.
if this does no work you need the fuser replaced
good luck
Oct 12, 2008 | Panasonic PanaFax UF-490 All-In-One Laser...
Have canon canoscan FB620u anyway to install on windows xp home edition
seems you accidentally closed the chat
can you send me the ID and password again?
May 24, 2008 | Canon imageRUNNER C3220 Printer
Brother MFC-5840CN Unable to clean
- Machine off
- Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press the "stop" button.
- press “99” to exit the maintenance mode.
Apr 25, 2008 | Brother MFC-5840CN All-In-One InkJet...
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
218 people viewed this question
Seeker5211
Seeker5211
