Question about Cameras
Dropped nikon coolpix S620 camera and lens will not extend shows lens error.
  • Cameras Master
  • 4,924 Answers
If it is from a shock ..than the lens motor has been damaged or the connection to it ..and the only way to fix it is to take it to a repair shop ..and have it opened..cause in the moment the lens will not come out ..there is nothing that you can do from the setting s..but ..if you hear the motor working (buzzing ) and the lens just are stuck ..and dont want to expand ..than here is a chance fro a fast fix..cause they may be just out of track ..or jammed..and this will not need any replacements ..but just to be opened and see what exactly is blocking them ..
Posted on Sep 01, 2010
L18 lens error
From Nikon site...
Why does my camera show "lens error" on the screen?
Having a "Lens error" message display on the camera's LCD display indicates a problem with the camera lens mechanism. This situation generally requires that the camera be sent to a Nikon Service Department for repair. Before doing this however, be sure to check these situations below:
One possible reason for this error is if the camera is switched on and the lens unit is prevented from extending. The camera will struggle for a second to extend the lens, then report the problem. Inspect the lens for any obvious obstruction, then turn the camera off, then on again. Usually, simply switching the camera Off then On again is enough to correct this problem.
Remove and recharge the battery. Retest.
If this does not help, then we regret the camera must be sent to our Nikon Service department as there are no user serviceable parts on Nikon Coolpix cameras.
Additionally, this link could helpfull: fixing-lens-error-on-digital-camera.html
Hope helps (remember to rate and commet this answer).
May 12, 2011 | Nikon COOLPIX L18 Digital Camera
I dropped my Nikon Coolpix L18. The lens does not come on and it gives lens error. the portion which covers the lens seems to be loos. I am in Africa and ready to try every thing to get it working to get...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 21, 2011 | Nikon COOLPIX L18 Digital Camera
My Nikon coolpix L3 appeared LENS ERROR how do i solve this fault
Oct 13, 2010 | Nikon COOLPIX L3 Digital Camera
Lens error
May 03, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
How can i fix a lens error on s610?
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 13, 2009 | Nikon COOLPIX S610 Digital Camera
Lense error
Very common problem with the Coolpix, unless under warranty the camera is not economical to repair.
Jul 02, 2009 | Nikon COOLPIX S10 Digital Camera
Lens error
This error... lens error.. can be the result of many abuses. If the lens is held back as it is extending, it can damage the tiny parts. If the lens is bumped while it is extended, it may damage the internal parts beyond repair. Sometimes the lens get off track as a result of a blow while extended.
If the camera is dropped, the lens mechanism can be damaged from the impact, even though it is not extended.
If you treat a digital camera with a lot of care, and put in a padded camera bag, you may extend the life of the camera.
Feb 09, 2008 | Nikon COOLPIX L3 Digital Camera
Camera
Anything you would try to do yourself would void your warranty. I suggest taking the camera back and see if they won't give you a replacement.
Usually, zoom errors occur when the lens is extended and gets bumped or dropped. Liquid and or sand can also cause these problems
Jan 02, 2008 | Nikon COOLPIX L10 Digital Camera
Cameras Logo
98 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
