Question about Amana 3.2 cu. ft. Top-Load Washer
Water continues to try to fill the machine but just drains out drain remains open
  • Amana Master
  • 43,501 Answers
The hoses are not hooked up right ...
Here is a tip that tells you how to fix that problem...
Water will not stay in Washing Machine
heatman101
Posted on Sep 01, 2010
2 Suggested Answers
  • 353 Answers
SOURCE: Incoming water wont shut off. It continues to fill
faulty water valve replace
Posted on Dec 21, 2009
What is F27 error code?
The F27 error code indicates an overflow condition. If the washer is overfilled and continues to fill with water, this would indicate that you have an inlet water fill valve that is stuck open. If you unplug the washer and water continues to fill the tub, then the inlet fill valve assembly will need to be replaced. Make sure that the drain system is properly installed according to the installation instructions. An improperly installed drain system could result if siphoning of drain water back into the washer.
Check to see if the drain pump is working properly to pump out the water. When the F27 occurs, the drain pump will run constantly to pump out the water. The door will remain locked. Shut off the water supply faucets behind the washer. If water is not being pumped out of the washer, you could have a clog in the drain pump or drain hose. The following link of a previous answer provides advanced troubleshooting for a drain problem:
Why won't my HE4t washer drain?
If the washer is not overfilling and the F27 remains even after the washer is drained, then it is likely that you have a failed pressure switch. A failed electronic control board in the washer could also cause this problem. To access the pressure switch, unplug the washer and remove the top panel. Screws at the very back of the top panel secure it to the washer. Remove these screws and pull the top panel slightly back and then up and off of the washer. Sometimes, you can reset a stuck contact in a pressure switch by tapping on it with the handle of a screwdriver. I you cannot reset it, the pressure switch will need to be replaced. If you have the same problem after replacing the pressure switch, you will likely need to replace the control board in the washer.
Aug 19, 2014 | Kenmore Washing Machines
Washing machine drain problem
Here's a few instruction's How to Diagnose Washing Machine Problems
Step 1:
If the washer won't start, check the power cord or reset the circuit breaker depending on the issue. It may be overheated and shut off temporarily. Let it cool for 30 minutes, and if it still won't start, call a professional.
Step 2:
If the motor transmission failed or the drive belt has broken, these need the assistance of a professional.
Step 3:
If the washer won't drain, clean out the drain hose and straighten any kinks. If the drain hose fits too tightly in the standpipe, adjust it to allow for a minimum of 1.25 inches for airflow so water can drain.
Step 4:
If the washer won't fill or fills slowly, turn the faucet handles counterclockwise as far as possible. This is usually the result of partially open faucets.
Step 5:
Call a profession if the washer overfills. This means the water-inlet valve or switch is defective.
Kindly regards,
-micromaster
micro & yakman unltd.
Mar 09, 2008 | Washing Machines
My dishwasher turns on and all the lights work. It sounds like it's filling up with water, but it never actually runs through any of the cycles. If I leave it running for a while it will continue to...
It's worth repairing.
Check water level switch inside the machine.
Check the inlet solenoid for proper operation. It might have got stuck and remain
in open condition always. You can reach this area by opening the back door of the machine. give a gentle tap with a wooden piece on the valve , it may return to the closed position.
Clean all the inlet and drain areas of the machine.
Sep 21, 2010 | Bosch SHU9915UC Dishwasher
Frigidaire glws1233as1 water runs continually. seems like a valve is stuck open or something. water is draining as fast as it is filling up.
your drain hose or drain is too low causing water to siphon from the tub as fast as it runs in. raise or loop the drain hose higher than the highest level of the tub.
May 28, 2010 | Washing Machines
Washing Machine on the blink mainly due to no spin/drain cycle wo
check your drain filter, get a wet vac and vacuum the water out, then open the drain plug at bottom and try to vacuum the drain to clear out debris......then turn on and test washer if it fills and drains if it fills with water and doesn't drain then your drain pump is defective........get your model number and source for a pump motor.................................
if it doesn't fill with water then your water fill switch is defective...............source for parts..............
if this helps out anyone a feed back would be good..........
Apr 16, 2010 | Miele Novotronic W1918A Front Load Washer
Water continues to fill after it should have
first does it over flow.if not pull your drain hose up from the drain till it is aleast the same level as the back of the waher control panel.
If the Drain hose is to far down in the pipe this will cause the water to drain out by gravity.the other least likely problem is a bad fill pressure switch.
Sep 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer fills, begins to agitate, then drains
Water siphoning out the drain line
If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
moz-screenshot.jpgThe washer fills and drains at the same time only on the rinse cycle.
Shut the machine off with timer during this period and raise the drain hose. If the water continues to drain, you will need to install an anti-siphon kit.
Please leave a solved rating before you sign out
Jan 31, 2009 | Whirlpool LBR4121JQ Top Load Washer
My washer will not fill during the cycle for high agitation
You may have a siphoning problem. Double check your drain hose and make sure it's not shoved down in the standpipe too far. The standpipe is the drain line at the wall. If your drain hose is placed too deep into the standpipe, or if you have the top of the standpipe sealed off, the washer will begin to fill and continue to drain at the same time. The symptom will appear as if the washer is constantly filling. You need to leave an air gap opening around the rim of the standpipe, and the drain hose should only be placed about 4 to 6 inches into the drain line. I hope this helps you. Post back if this is not the problem you are experiencing and I will try to provide you with a better solution. Let me know if you have any questions.
Apr 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer fills then drains
Daisy, check your drain hose going into the drain. It sounds like you have a siphoning problem. If the drain hose does not have a air gap the water filling will siphon right out. Check this first and post back, Catriver.
Sep 21, 2006 | Kenmore 98702 Stacked Washer/Dryer
Amana 3.2 cu. ft. Top-Load Washer Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
