Question about Linksys Computers & Internet
Would like to set a password for the linkssys wrk54g
  • 550 Answers
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Posted on Sep 01, 2010
Lost installer/set up driver linksys model wrk54G
You don't need the disk. You should be able to log-in to the web interface of the router at this URL: http://192.168.0.1/
If you don't remember the password, you'll have to reset the router to factory defaults and then log-in with password "admin".
Dec 05, 2011 | Linksys Computers & Internet
I'm trying to connect a Samsung BD-C6500 Blu-ray player to the Internet via a Linksys WRK54G router using the wired ports NOT wireless. The Blu-ray passes all network tests except Internet connectivity due...
Here is the manual (http://downloadcenter.samsung.com/content/UM/201001/20100120173529671/BD-C6500-0120.pdf) ..I typed 192.168.1.1 into my internet explorer address bar and it went to my router options from there I assigned a port
Feb 11, 2011 | Linksys WRK54G Wireless Router
(1) Can more than one WPC54G wireless notebook cards be used with a WRK54G router? (2) does the version matter? Thanks, Jack
Yes you can use multiple wireless card for this router and any version will do, any wireless adapter will work with the WRK54G fine.
Jan 15, 2011 | Linksys 2.4 GHz 802.11b Wireless - B...
I am trying to set up a Linksys WRK54G at home that I previously had at work and not sure of the password. Should I go buy a new router or can this be solved?
No since the router was working fine. Locate at the back of the router a small hole and use a paperclip to push the internal button for 10 seconds (while the router is at power on state). Reseting the router will come to the factory settings and you can log in with your browser using the defaults (user admin, pass admin)
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 22, 2010 | Linksys Wireless-G WRT54G Router
How do I set security for my Linksys WRK54G 2.4GHZ
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 04, 2010 | Linksys Computers & Internet
Set up my linksys wrt52g2 v1
Go to this site and scroll down to the section "Configuring your Router to work with Port Triggering"
http://portforward.com/english/routers/port_triggering/Linksys/WRK54G/Warcraft_III.htm
The username & password for the router is by default admin/admin.
Hope this helps
Mar 16, 2009 | Computers & Internet
WRK54G as a repeter
Okay, if it is a wireless repeater, you simply cannot, the WRK does not have such capabilities, but WIRED, that may work.
By default the routers IP is 192.168.1.1, so turn off the DHCP of the WRK, then change the IP to 192.168.1.something else. for the cable routings, from the primary router's ethernet cable should be plugged in to any LAN port of the 2nd router.
then you can relocate the 2nd router to where it has to be as long as the cable reaches it (not longer than 200 feet)
for the wireless settings, just make a different wireless networks for both routers.
if you have other questions just lemme know
Nov 02, 2008 | Linksys Wireless-G WRT54G Router
The server 192.168.1.1 at Linksys WRK54G V1.1 requires a username and password.
linksys username is blank
password is admin
if these are not correct press reset on back and try again, reset will set to default settings.
Apr 19, 2008 | Computers & Internet
Linksys wrk54g setup
Many routers have a hole in them; stick a paper clip in, and it will reset itsef to its defaults. Go to linksys online to get the info you need--it will tell you it's default settings, and you can download the instructions. If you have DSL cable, the router will detect its settings automatically. Remember to encrypt it, or any one of your neighbors can use it to connect to the internet wirelessly. You won't have to bother if you connect through a cable to your pc.
Feb 29, 2008 | Linksys Wireless-G WRT54G Router
Linksys WRK54G versus WRT54G Firmware
Hi...
The WRK54G is actually a stripped down version of the WRT54G that was bundled with a wireless network adapter and sold under the kit name WKPC54G.
From what you say in your question I gather that you have a WRT54G already in place as your access point, and it is what is connected to your WAN. To use the WRK54G as a range extender repeater you should do the following:
1. Turn off DHCP
2. Turn off NAT
3. Assign a fixed IP that is in your Class C Block
4. Define the WRT54G as the Gateway
With this configuration it now should function as an extender/repeater, and any clients connecting to it will be serviced by the DHCP on the master router.
I hope that this helps.
Nov 15, 2007 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
